Finding coordinates of a point in a circle with angle
AlicanC
I have a point (x,y), a distance (d) and an angle (a). I need a method to find a point using x,y,d and a. For example:
http://c.imagehost.org/0836/03082008299.png
I will apply this on a 3D environment, but I am not going to use the 3rd dimension so it's safe.
This is also about programming, but I am capable of applying methods in the programming language so I asked it here.
Mathematics news on Phys.org
[tex] (x_?,y_?) = (x+d\cos\alpha,y+d\sin\alpha)[/tex]
Thanks for the answer, but I have a problem. I wrote some code to put this in action. The code starts from "0" and adds "20" to the angle until the vaule is greater than to "360". I don't know why but the code produced this:
http://c.imagehost.org/0346/2008-08-03_092702.png
As you can see there are some mistakes. All are getting repeated but the ones I marked. Here is the debug output I get:
(1) Center of the circle located at (-49.013168, -1082.446166)
(1) Drawing at (50.986831, -1082.446166) Angle is 0.000000
(1) Drawing at (-8.204959, -991.151611) Angle is 20.000000
(1) Drawing at (-115.706977, -1007.934875) Angle is 40.000000
(1) Drawing at (-144.254455, -1112.927246) Angle is 60.000000
(1) Drawing at (-60.051891, -1181.835083) Angle is 80.000000
(1) Drawing at (37.218719, -1133.082763) Angle is 100.000000
(1) Drawing at (32.404930, -1024.385009) Angle is 120.000000
(1) Drawing at (-68.794525, -984.422180) Angle is 140.000000
(1) Drawing at (-146.576110, -1060.503662) Angle is 160.000000
(1) Drawing at (-108.859176, -1162.561401) Angle is 180.000000
(1) Drawing at (-0.294399, -1169.775878) Angle is 200.000000
(1) Drawing at (50.595352, -1073.606323) Angle is 220.000000
(1) Drawing at (-16.435035, -987.901672) Angle is 240.000000
(1) Drawing at (-122.032585, -1014.122192) Angle is 260.000000
(1) Drawing at (-141.187133, -1121.227050) Angle is 280.000000
(1) Drawing at (-51.222831, -1182.421752) Angle is 300.000000
(1) Drawing at (41.357345, -1125.261718) Angle is 320.000000
(1) Drawing at (26.953659, -1017.415100) Angle is 340.000000
(1) Drawing at (-77.382278, -986.554565) Angle is 360.000000
As you can see some values are too close. I am really bad at trigonometry, so I can't find the problem.
The center is at (-49, -1082) and your first point, with the angle, 0 is at
(51, -1082) then radius, d, is 100.
So, when the angle is 20 the point should be
[tex]100(\cos(20)) + -49 \approx 45[/tex]
[tex]100(\sin(20))+ -1082 \approx -1048[/tex]
But you have:
*Could you be in radians instead of degrees?
Ah, you are right! I was making calculations with radians.
Thank you both so much! I was trying to figure this out for two days! Normally I post my questions to forums related to coding or just ask my friends, but can't get an answer :D
Always a problem if you forget. When I get errors like that, the first thing I do is to check the mode on my calculator. Lol.
