Collapsing fields and coil polarity, freewheel diode, .
The discussion revolves around the behavior of a DC coil (relay) when it is de-energized, specifically focusing on the induced current and voltage polarity changes, as well as the role of a freewheeling diode. Participants explore concepts related to Lenz's Law, transformer behavior, and the implications of collapsing magnetic fields.
  • One participant questions whether the induced current when a DC coil is de-energized would oppose the change in current and if it would flow in the same direction as when the coil was energized.
  • Another participant suggests that when the coil is de-energized, it acts as a power source, causing a reversal in the relative polarity across the coil.
  • A participant draws a parallel between the behavior of the coil and a transformer, discussing how the induced voltage in the secondary can create a potential difference even when the circuit is not closed.
  • There is mention of the initial voltage pulse having the opposite polarity when the switch in a transformer circuit is opened, depending on the primary circuit configuration.
  • A reference to flyback topology is provided, indicating a related concept in the discussion.
Participants express differing views on the behavior of induced currents and voltages in the context of de-energizing coils and transformers. There is no consensus on the interpretation of Lenz's Law in this scenario, and the discussion remains unresolved.
Participants reference various assumptions about circuit configurations and the behavior of inductive components, but these assumptions are not fully explored or agreed upon.
mmalf_mi
When a DC coil (relay) is denergized, shouldn't the collapsing field cause a current that would oppose the change in current? Wouldn't that induced current be in the same direction as when the coil was enegized? Not seeing how a freewheeling doide gets forward biased. If I apply Lenz Law, current will flow in a direction that will oppose the force that caused it. The collapsing field caused it (denergizing the coil), the current direction to oppose the collapsing field would be the same current direction that caused an expanding field (energizing the coil). Shouldn't there be a voltage spike across the coil with the same polarity as when the coil field was energized and steady state?
Please shed some light on this EET.
Welcome to PF.
You generally seem to have the right idea.
However, note that when the current going to the coil is turned off the coil becomes a power source.
So with the external drive terminal 1 is at a higher voltage potential than terminal 2.
With the drive turned off terminal 2 is staying at the same (for illustration) voltage (because the coil continues the current) while terminal 1 is now at a zero potential.
The relative polarity across the coil reverses.
NoTime,
Thanks for your response. Is this the same as when the secondary voltage of a transformer is 180 degrees out of phase with the primary and the secondary has no load? We read a voltage because the induced secondary circuit is not closed, but electrons have still moved to one side of the wire's end (the - side means excess of electrons), and the other end now has fewer electrons (the + side). Lenz Law would still prevail, the collapsing field would try to oppose the decreasing current by boosting the current in the same direction as when the switch was closed on the coil. However, there is not a closed circuit for current to flow, it just moves electrons to one end and creates a potential difference.
I got this from another website. I did not think it was a good technical response:
"However, when the switch is opened, the coil's inductance responds to the decrease in current by inducing a voltage of reverse polarity, in an effort to maintain current at the same magnitude and in the same direction."
Great to have people to go to. Thanks again.
mmalf_mi
For a transformer secondary with switched DC.
When the switch is closed you will get a voltage in one polarity.
When the current in the primary reaches the limit defined by E/R then the secondary voltage is zero.
Just what you get when the the switch is opened depends on what the primary circuit is (with the switch open), but the initial voltage pulse will have the opposite polarity.
9K
