Solving Exponential Rates: Intervals & Solutions
  • Thread starter Thread starter epsilonzero
    Exponential
epsilonzero
Hey, I'm having trouble starting this assignment. If you could just tell me how to get started and the path I should be on then that would be great and I can do the rest. Here are the questions:
1) Solutions to x= - x^k for x0>0 satisfy x(t) goes to 0 as t goes to infinity. Characterize the rate at which these solutions go to 0.
2) How do things change for x'= -m x^k for m>0?
I think question 1 will have several answers for various intervals but I'm how do I find these intervals?
The first problem makes no sense at all. "Solutions to x= -x^k" are numbers that do not "go" anywhere as t goes to infinity. I assume you mean "dx/dt= -x^k"?
In that case you should be able to integrate dx/x^k= -dt without difficulty. The same is true for x'= -mx^k. Integrate dx/x^k= -mdt. The case k= 1 will have to be treated separately.
I just copied and pasted so yeah, it seems like there were a few problems. The x should have been an x'. Also I think the question is asking what rate does x(t)->0.
What I've done so far is
x'=-x^k
(-x^-k)dx=-dt
-Int(x^-k)dx=Int(1)dt
1/(-k+1)*x^(-k+1)=t+C
Where do I go from here to find the rate at which x(t) goes to 0?
For number 2 I have
x'=-mx^k
(x^-k)dx=-mdt
Int(x^-k)dx=-Int(m)dt
1/(-k+1)*x^(-k+1)=-mt
Now how do I characterize the effect m has? I see that k=1 will have to be treated separately because there will be 0 in the denominator.
Thank you for your help.
I'm still at this step: x=(t(k-1)+C)^(1/(1-k)) and I want to know at what rate x(t) goes to 0 for different intervals of k. I'm not sure how to figure out what these intervals should be or how to calculate the rate.
I think for rate there's an equation (x(t)-a)/(e^mt) as t->infinity where m is the rate and a is an x value. But I don't know what to use for a. Would a be 0?
Then the second equation is x=(mt(k-1)+C)^(1/(1-k)). What effect does m have? Would it just speed up the rate that x(t) approaches 0?
Any help is appreciated.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
