Thread Closed
Simple question regarding higher frequency vs lower frequency
Share Thread Thread Tools
Oct3-08, 06:49 PM   #1
Damping is negligible for a 0.145 kg object hanging from a light 6.30 N/m spring. A sinusoidal force with an amplitude of 1.70 N drives the system. At what frequency will the force make the object vibrate with an amplitude of 0.440 m?
2. Relevant equations
I don't know how to put formulas in here but basically find out the initial omega value, then plug it into the forced oscillations amplitude equation to get the angular frequency. Then use the frequency formula to get your frequency.
3. The attempt at a solution
Here's the problem!!
The question asks me for 2 solutions -- higher frequency and lower frequency.
I obtained the higher frequency given the equations above and it is indeed the correct answer. That answer is 1.33 Hz.
Now how do I get the lower frequency? It's not -1.33 if anyone is wondering.
Thanks for the help guys!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct4-08, 07:26 AM   #2
Mentor
Welcome to PF, Doc Z.
It's been a while since I solved this type of problem. But I remember that the amplitude equation involves frequency terms that are squared.
When you worked through your solution, you probably took a square root at some point. Did you consider the negative square root as well?
Oct11-08, 10:57 PM   #3
Sorry for the late response, for some reason I didn't get an email when I receive a reply to a thread.
Thank you very much! It was just a stupid mistake on my part, I completely forgot about the negative sign.
Oct12-08, 07:22 AM   #4
Mentor
Quote by Doc Z View Post
... for some reason I didn't get an email when I receive a reply to a thread.
Yeah, that happens sometimes. It seems to be a bug in the system.
If you click on "My PF" at the top left of the page, you'll see a list of recent replies in threads you are subscribed to. I have abandoned email notification in favor of this other way of checking for recent replies.
Glad the HW problem worked out.
Thread Closed
Thread Tools
Similar Threads for: Simple question regarding higher frequency vs lower frequency
Thread Forum Replies
Parallel RLC circuit: find resonant frequency and Input at that frequency Introductory Physics Homework 7
Why higher frequency allows the signal to carry more data. Introductory Physics Homework 3
Frequency output = sum of 2 frequency inputs (Digital) Electrical Engineering 9
which has a higher frequency? Quantum Physics 3
Which photon has the higher frequency? Chemistry 15
