Calculating Work for Buried Gas Tank
  • Thread starter Thread starter Sheneron
    Gas Tank Work
Sheneron
A cylindrical gasoline tank with radius 4ft and length 15 ft is buried under a service station. The top of the tank is 10ft underground. Find the amount of work needed to pump all the gasoline in the tank to a nozzle 3 ft above the ground. Gasoline weighs 42lb/ft^3.
So the way I have started is by setting a cylinder with the specified radius centered at (0,0). With that I know the top is at (0,4), bottom is at (0,-4) and the place it needs to reach is y = 17 (13ft above the top of the cylinder).
I divide the cylinder into strips of thickness delta y. So I know I need to find the weight of each of those strips and multiply it by the distance it must travel (17-y).
I have the density so I really now just need the volume of those strips. Volume = length * width * thickness. I have the thickness (delta y), the length (15), but I need the width.
I can't figure out how to find the width of the strips. I know that at y = 0 the width is 8 and at y=4 and y = -4 the width is 0.
Something like
width = 2\sqrt{16-y^2}
would tell me the width with respect to y, but that would only be true from y=-4 to y=4, and it needs to stop after that.
Any advice would be appreciated thanks.
Wait tell me if this would work:
thickness = \Delta(y)
length = 15
weight = 2\sqrt{16-y^2} * \Delta(y) * 15 * 42
and the height = 17 - y
so the integral would be:
\int_{-4}^{4} 1260\sqrt{16-y^2}(y-17) dy
One important thing you did not specify: is the axis of the cylinder vertical or horizontal? You seem to be assuming it is horizontal. If so then, yes, width= \sqrt{16- y^2}. You will only be integrating from y= -4 to 4 so the fact that it "has to stop at 4" is irrelevant. Looks to me like your final integral is correct.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
