Fringe spacing for a diffraction grading (wave optics)
The discussion revolves around a problem involving a diffraction grating with 550 lines/mm illuminated by light of wavelength 550nm, and the objective is to determine the number of bright fringes visible on a 3.1-meter-wide screen located 2.1 meters behind the grating.
  • Participants discuss the application of the formula for fringe spacing and question the assumptions made regarding angles and the small-angle approximation. There is exploration of the relationship between diffraction orders and the number of bright fringes, with some participants expressing confusion about including the central maximum.
The discussion is active, with participants offering insights and questioning the validity of certain assumptions. There is an acknowledgment of the need to consider angles more carefully, and some guidance has been provided regarding the relationship between diffraction orders and bright fringes.
Participants note that the angle used in calculations may not be small, which could affect the results. There is also mention of differing wavelengths in related problems, which may introduce additional variables to consider.
spaghed87
A 550 lines/mm diffraction grating is illuminated by light of wavelength 550nm.
How many bright fringes are seen on a 3.1-m-wide screen located 2.1m behind the grating?
[tex]\Delta[/tex]Y = [tex]\lambda[/tex]*L/d
where Y is equal to the fringe spacing... lamda is equal to the wavelength. d is equal to the separation... which is 0.001m/550lines in this case.
I did [tex]\Delta[/tex]Y=(550*10^-9m*2.1m)/(~1.81*10-6) = 0.63525m
So then the width of 3.1m divided by the fringe spacing ~1.81*10^-6 gives me 4.87 which is unitless because it is n and equal to the number of gaps... now there are two fringes per gap so shouldn't the answer be 6? well... the last one is cut off so i can't round... so that would be 5 right? but mastering physics (my online homework website) still says I'm wrong. any ideas?
ΔY = λ L/d
I looks like a small-angle approximation for a trig term was used here. But the screen subtends a rather large angle.
Perhaps using the exact formula, with the trig term, would work better.
I saw another thread that read:
"d*sin theta = mt
t = wavelength
m = d*sin theta/t
I don't have the angle so I just omitted it assuming it would be very small and I did...
m = d/t = 3.4 so 3 diffraction orders
Is this correct? "
I also got around ~3 diffraction orders for my problem which turned out to be the number of bright fringes. Is that really true that the diffraction order is equal to the number of bright fringes in this case? I thought you had to add one to acount for the m=0 central maximum or something... :confused:
Yes, the number of diffraction orders is the same as the number of bright fringes.
The angle is not small and must be accounted for. And what you actually did was take sin(theta)=1, for which the angle would be 90 degrees.
And yes, you need to include the m=0 central maximum, as well as negative values of m.
For theta, use the angle at the edge of the screen.
I know this is an old post, but I wanted to tack onto it. I just did this problem for my physics course, except my problem had a wavelength of 530nm.
The number of bright fringes on the screen is calculated from the formula:
d*sinθ = mλ (distance between successive slits = sine of angular distance to bright fringe m times wavelength)
m = (d*sinθ)/λ
This is a maximum when θ = π/2 (sinθ = 1)
So, m = d/λ = 1.67e-6m/530e-9m = 3.15 (round to nearest integer) = 3.
This gives you the number of bright fringes above the central maximum. Double that to get the number of bright fringes on both sides of the central maximum and you now have 6 bright fringes. Add one to that (for the m = 0 [central] maximum) and you get an answer of 7 bright fringes.
My question, though, is how would an angle of π/2 even show anything on the viewing screen? Wouldn't an angle of π/2 be parallel to the screen, and thus the bright fringe at that angle would never be able to be physically located on the screen?
True. θ must be strictly less than π/2, not ≤ π/2.
But this does not change the result, which really says that m<3.15. So m=3 is still the largest that m can be.
Excellent... Thanks for making sense of that for me!
9K
12K
11K
18K
