What Forces Act on Three Blocks on a Frictionless Surface?
  • Thread starter Thread starter ScullyX51
    Blocks Tension
The discussion centers on the dynamics of three identical blocks connected by ideal strings on a frictionless surface, subjected to a horizontal force F. The tension between blocks B and C is established at T = 3.00 N, with each block having a mass of m = 0.400 kg. The correct approach to determine the force F involves calculating the acceleration as F/(3*m), leading to the tensions between the blocks being 2/3*F for A:B and 1/3*F for B:C. The initial calculations presented were incorrect due to misunderstanding the relationship between force, mass, and acceleration.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of tension in ideal strings
  • Concept of frictionless surfaces in physics
  • Basic algebra for solving equations
  • Study the derivation of tension in connected systems
  • Learn about dynamics on frictionless surfaces
  • Explore the implications of mass distribution on acceleration
  • Review examples of multi-body problems in classical mechanics
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to forces and tensions in connected systems.
ScullyX51
Three identical blocks connected by ideal strings are being pulled along a horizontal frictionless surface by a horizontal force F_vec. (Intro 1 figure) The magnitude of the tension in the string between blocks B and C is T = 3.00 N. Assume that each block has mass m = 0.400 kg
What is the magnitude F of the force?
What is the tension T:AB in the string between block A and block B?
F=ma
I am unsure of how to approach the first part of the problem. For the second part, since t is the only force acting this the block,
I have: T=ma
I solve for A from the first part of the equation where t is given as follows:
t=ma
3=.400a
a=3/.4
a=7.5 m/s^2
I plugged this into to solve for the other tension as follows:
t=ma
t=.4*7.5
t=3
Mastering physics is saying the tension and the acceleration is wrong. Where did I screw up?
What is the order of your blocks?
T <---{A}--{B}--{C}
Generally, whatever your force is, the acceleration will be F/(3*m) and then the intermediate tensions would be whatever force is needed to keep the blocks remaining moving with that acceleration.
In the example above that would be 2/3*F between A:B and 1/3*F between B:C
  • · Replies 25 ·
