Thread Closed
Dynamics, falling balls.
Share Thread Thread Tools
Nov20-08, 05:06 PM   #1
2. Relevant equations
I'm not sure what equations to use here, or even wether or not I need to use calc. Unfortunately we just started dynamics and most students don't know how to integrate yet (including me)
v = dx/dt
a = dv/dt = d2x/dt2 = v dv/dx
Uniform rectilinear motion: x = x0 + vt
Uniformly accelerated rectilinear motion:
v = vo + at ; x = xo + vot + 1/2at2; v2 = v2o +2a(x-xo)
where o in all the above = initial.
3. The attempt at a solution
I don't even know where to start with this one. hence my question for help.
We know that a = 9.81m/s2 and also that every .5 second there is a ball dropped.
Do i have to integrate anything?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov20-08, 05:15 PM   #2
As you have stated already, a is a constant (9.81 m/s^2). With uniform acceleration, there is no need to know how to integrate.
Nov20-08, 09:40 PM   #3
ok. Well I think I have a solution then, but it's not very fancy (I just used techniques from high school physics).
1) I first contemplate ball #1 to find the final velocity and the time it is at 3m.
Vf2=Vi2+2ax
Vf2= 02+2(9.81)(3)
Vf=7.67m/s
Now the time:
x=( (Vf+Vi)/2)t ; 3m=((7.67+0)/2)t ; t= .78206s
Now I say Ball #2 is dropped .5s after ball #1 and solve for it's final velocity
a=(Vf-Vi)/t ; Vf= 2.767m/s
Now I solve for displacement between ball 1 and 2 according to their respective instantanous(or final) velocities and time being dropped apart from each other.
Where x is displacement.
x=( (Vf+Vi)/2)t
x= ((7.67+2.767)/2)*0.5
x= 2.6097m
Can someone confirm this is correct methodology and answer?
Thanks,
Nov20-08, 09:52 PM   #4
Quote by twofish View Post
High school physics is all I use everyday
Vf2=Vi2+2ax
Vf2= 02+2(9.81)(3)
Vf=7.67m/s
Now the time:
This part is correct. (It was probably easier to use the formula for displacement, x = Vi t + 1/2 a t2.)
x=( (Vf+Vi)/2)t
x= 2.6097m
Thanks,
I don't quite understand your explanation for this part of your solution, but if you're saying what I think you're saying, the answer is correct! Are you saying that the problem is equivalent to the distance moved by a ball starting with an initial velocity of 2.767m/s in 0.5 sec?
A simpler solution might be to just find what distance ball #2 travels in 0.28206 seconds.
Nov20-08, 10:13 PM   #5
Actually.. i didn't articulate that very well i suppose. But you're right, if I just solved for the distance ball #2 travelled and deducted that figure from 3m it should tell me the spread between them and hence h (or x).
Thread Closed
Thread Tools
Similar Threads for: Dynamics, falling balls.
Thread Forum Replies
[SOLVED] Dynamics Question (water falling from the side of a tank) Advanced Physics Homework 2
Dynamics of a Falling Rod Introductory Physics Homework 8
Two balls falling and bouncing one off the other Introductory Physics Homework 22
Free Falling (dynamics question) Advanced Physics Homework 2
Gravity And Balls Falling Introductory Physics Homework 5
