How much power will 10 grams of plutonium produce?
  • Context: Graduate
  • Thread starter Thread starter The000Agent
    Grams Power
The discussion revolves around the energy production potential of 10 grams of plutonium, specifically exploring the theoretical energy output if fully converted to energy, and comparing it to other reactions such as matter-antimatter annihilation. The scope includes theoretical calculations, nuclear physics concepts, and efficiency considerations in nuclear reactions.
  • One participant calculates the energy from 10 grams of matter using the equation E=mc², suggesting that if 100% of the mass is converted, it could yield approximately 1,800 megatons, assuming an antimatter-matter reaction.
  • Another participant clarifies that a megaton is an energy unit equivalent to the blast energy of one million tons of standard military explosives, providing a conversion to joules and suggesting that 10 grams of matter and antimatter would yield about 430 kilotons.
  • A participant questions the feasibility of combining antimatter and matter in a device, indicating uncertainty about the practical aspects of such a reaction.
  • Discussion includes the storage of antimatter in magnetic fields and the challenges of producing sufficient antimatter, with one participant noting the long timescales required for production.
  • Another participant emphasizes that the original question may imply a focus on plutonium-239 and its fission properties, providing an estimate that 10 grams could yield around 40 tons of TNT equivalent under realistic conditions, acknowledging that 100% efficiency is not achievable in nuclear explosions.
Participants express differing views on the energy output of plutonium versus antimatter, with some advocating for the potential of antimatter reactions while others focus on the practicalities of plutonium fission. The discussion remains unresolved regarding the exact energy output and the feasibility of the proposed reactions.
There are limitations in the assumptions made regarding efficiency in nuclear reactions, the definitions of energy units, and the practical aspects of antimatter storage and production. These factors contribute to the uncertainty in the calculations and claims presented.
The000Agent
How much power will 10 grams of plutonium produce in megatons if 100% of the 10 grams is converted into energy?
e=mc^2
The thing is... to do this. You would essentially need an antimatter-matter reaction.
So plutonium is more or less a unneccessary component. You could just plain hydrogen. You simply need mass. Then you need 1:1 ratio so 10 grams of matter + 10 grams of matter.
So the M is double the M.
So basically...
0.02Kilograms * 300,000,000 * 300,000,000 = Joules.
1,800,000,000,000 Kilojoules
Then 1 megaton = 1 million tons.
So 1,800,000,000/1,000,000
So assuming I calculated correctly :)
1,800 megatons
Now you can go with nuclear bomb... but it is ~1% efficient.
Largest nuclear bomb I am familiar with was 50megatons.
So the 100% efficiency of antimatter-matter is amazing.
A "megaton" is not what you would think. It is an energy unit, corresponding to the blast energy of one million ton of a standard military explosive.
http://en.wikipedia.org/wiki/Megaton
A megaton corresponds to about 4.184 PJ (peta joule), 4.184E15 J.1 kg of matter + 1 kg of antimatter releases about 43 Megaton, which is comparable to the Tsar Bomba that the Soviets blew up http://en.wikipedia.org/wiki/Tsar_Bomba
So 10 g + 10 g will give you 430 Kiloton, which is what a medium-size nuclear weapon will give you (about 30 times the Hiroshima bomb).
I'm not sure how you put anti matter and matter in the same device, Does anyone know how?
The000Agent: you can store the anitmatter in a magnetic field cage, and then when detonation, you just shut of the magnetic cage.
Vanesch, with current rate at producing antiprotons, it will take several million of years even to procoude 1gram ;-)
First of all, your question is very vague. Let me try to fill in the blanks.
Since plutonium is mentioned, I'm guessing that you're talking about old-fashioned nuclear decay, not matter-antimatter annihilation.
There are two industrial isotopes of plutonium, 238 and 239. 238 is used as a power source on space probes and 239 is used as a fuel in nukes. Since you want the answer in megatons, and megatons are a nuke term, you must be thinking about 239.
One gram of plutonium-239 can produce 70 GJ (7E10 J) of energy when fully fissioned. That's around 15 tons. 10 grams = 150 tons.
In a nuclear explosion, you never get 100% or near 100% efficiency. Your plutonium is dispersed by the explosion before it has a chance to fission fully. Well-designed bomb could have 25% efficiency. Your 10 grams would be the equivalent of 40 tons of TNT.
  • · Replies 18 ·
  • · Replies 0 ·
