Prove Inequality with Mean-Value Theorem
The discussion revolves around proving the inequality \( \frac{1}{9} \leq \sqrt{66} - 8 \leq \frac{1}{8} \) using the Mean Value Theorem (MVT). Participants explore the application of MVT in the context of the function \( f(x) = \sqrt{x} \) over the interval from 64 to 66.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the definition of the interval for \( c \) in the MVT and its implications for the inequality. They question how to apply the MVT to prove the inequality and explore the relationship between the values of \( c \), 64, 66, and 81. Some participants express confusion about the steps and seek clarification on the reasoning behind certain transformations and inequalities.
The discussion is active, with participants sharing their reasoning and attempting to clarify each other's thoughts. Some guidance has been offered regarding the use of the MVT and the properties of inequalities, but there is no explicit consensus on the final proof or the correctness of the approaches taken.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is ongoing questioning of assumptions and the definitions of the variables involved in the inequality.
DeusExa
Prove that 1/9 ≤ sqrt(66)-8 ≤ 1/8
Question comes with:
Use the mean value theorem
(f(b) − f(a)) / (b − a)
I can do "find c" problems fine with MVT, but I have no idea how to prove an inequality. I tried using sqrt(x) as a function, but got stuck. Don't know C.Thanks!
You must remember the interval where c is defined. c is in ]a,b[, where a = 64, and b = 66, now we can write 64 < c < 66. What can you do with the c in this inequality and the one in the MVT?
How did you get a = 64, and b = 66 ?
Do you use sqrtx as function for MVT?
sqrt 64 = 8 and sqrt 66 appears in the inequality. Now it should be clear whether sqrt x should be the function.
Since [itex]\sqrt{64}= 8[/itex], it should be clear that they are using [itex]f(x)= \sqrt{x}[/itex] on an interval from 64 to 66: (f(66)- f(64))/(66-64)= [itex](\sqrt{66}- 8)/2[/itex] and that is equal to the derivative, [itex]1/2\sqrt{x}[/itex] for some value of x between 64 and 66. Obviously the largest that can be is [itex]1/2\sqrt{64}= 1/2(8)[/itex]. What is the smallest it can be?
Hi, I used sqrtx and got what you got, being
1/2sqrtx≤(sqrt(66)-8)/2≤1/2sqrtx
which then equals
1/2sqrtx≤(sqrt(66)-8)/2≤1/16
then, times 2 to clear the 2 in the denominator,
1/sqrtx≤sqrt(66)-8≤1/8
This is 2/3 of the proof done, but how do you find the smallest? Logic says that it should be 81, so equals 1/9, which ends the proof, but I'm not sure how.
Do you remember the properties of the inequalities? The one you need to remember here is if x < y and y < z, therefore x < z.
I don't quite get what you mean, how that applies...please explain...
c in the interval ]64, 66[, so we can write 64 < c < 66, but we want 81 in there, 64 < c < 66 < 81. How can you use the property to only have 64, c and 81 in the inequality?
So c<66, 66<81, then x<81...then 64<c<81, then value of x is between 64 and 81, and then you can plug in 64 and 81 on the two sides of the inequality
giving you 1/9≤sqrt(66)-8≤1/8
Is that it?
Not really plugging, because you work the MVT with the inequality to prove the initial statement.
OK, to reiterate:
64 < c < 66 (sqrts)
Then, by using MVT, and 66=a 64=b, you get
(sqrt66 -8)/2
Then find derivative of sqrtx, which is 1/2sqrtx.
Then, using transitive property, prove that
Then,
So, 1/2sqrt81≤(sqrt(66)-8)/2≤1/2sqrt8
So, times 2 all sides
Getting 1/sqrt81≤sqrt(66)-8≤1/sqrt64
Equals 1/9≤sqrt(66)-8≤1/8
And that is proven. Am I right?
How did you get this 1/2sqrtx ≤ (sqrt(66)-8)/2 ≤ 1/2sqrtx?
I would use the MVT to have sqrt(66)-8 = 1/sqrt(c), then transform the inequality 66 < c < 81 to put the sqrt(66)-8 in it.
My bad.
64 < c < 66 (sqrts)
(sqrt66 -8)/2
then (sqrt66 -8)/2 = 1/2sqrt(c)
then sqrt(66)-8 = 1/sqrt(c)
c=1/(sqrt66-8)²
then 64 < 1/(sqrt66-8)² < 81
then 1/64 < (sqrt66-8)² < 1/81
then 1/8 < sqrt66-8 < 1/9
But that is reversed with what I want to prove
? What Happened?
bump...have to leave in 10 min
That's another properties of the inequalities, if 0 < x < y, then 0 < 1/y < 1/x.
1/9<sqrt66-8 < 1/9 !
Yay! Proof completed!, right?
It seems right, I would've done it a slightly different way. With 64 < c < 81 I changed it to sqrt(64) < sqrt(c) < sqrt(81), 1/8 > sqrt(c) > 1/9, then with the MVT you have sqrt(66)-8 = 1/sqrt(c), then you substitute 1/8 > sqrt(66) - 8 > 1/9. But that's just me.
thanks!
  • · Replies 105 ·
13K
