Anyone know how to integrate (Tanx)^2(Secx) thanks
  • Thread starter Thread starter coverband
    Integrate Thanks
To integrate (tan(x))^2(sec(x)), start by rewriting tan(x) and sec(x) in terms of sine and cosine, leading to the expression sin^2(x)/cos^3(x). By factoring out a cosine, the integral simplifies to sin^2(x)cos(x)/cos^4(x), which can be transformed using the substitution u = sin(x). Alternatively, using the substitution u = tan(x/2) allows for a different approach, yielding an integral that can be solved through partial fractions. The final result involves integrating sec^3(x) and sec(x), with the latter evaluated using logarithmic identities.
coverband
(Tanx)^2(Secx)
Mathematics news on Phys.org
Not necessarily the simplest: tan(x)= sin(x)/cos(x) and sec(x)= 1/cos(x) so tan^2(x) sec(x)= sin^2(x)/cos^3(x). That involves cosine to an odd power so we can "factor out" one to use with a substitution. Specifically, multiply both numerator and denominator by cos(x) to get sin^2(x)cos(x)/cos^4(x). cos^4(x)= (cos^2(x))^2=(1- sin^2(x))^2 so let u= sin(x). Then du= cos(x) dx so the integral becomes
\int \frac{u^2}{(1-u^2)^2} du
That integral can be done by partial fractions.
Here's another substitution you could make, inspired by stereographic projection, and it always works when you have a rational function of trigonometric functions of x.
Let u = \tan(x/2). From that, using various trigonometric identities, obtain the following:
\sin x = \frac{2u}{1+u^2}; \cos x = \frac{1-u^2}{1+u^2}; dx = \frac{2 \,du}{1+u^2}
and in particular
\tan x = \frac{2u}{1-u^2}; \sec x = \frac{1+u^2}{1-u^2}.
Then your integral becomes
\int \tan^2 x \sec x \,dx = \int \frac{8u^2}{(1-u^2)^3} \,du
which can be done by partial fractions. Admittedly, you've ended up with a higher degree denominator than what HallsofIvy gets, but again it always reduces a rational function of trig functions to a rational function of u, which can be done by partial fractions (or if you're lucky, substitution).
Expanding using Pythagorean Identities yields
\int \tan^2 x \sec x dx = \int \sec^3 x dx - \int \sec x dx
The second integral, upon multiplying both the numerator and denominator by (sec x + tan x), evaluates to log |sec x + tan x|+ C
The first requires integration by parts. You should be able to see the integral you want on both sides of the equation now, so isolate it and solve.
My calculus book gives an algorithm that can be used to solve all such kinds of trigonometric integrals. Doesn't yours have a similar thing?
You're probably thinking of the u = tan(x/2) thing I mentioned above. :-)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
