| Thread Closed |
Pressure at the center of a planet |
Share Thread | Thread Tools |
| Dec9-08, 10:57 PM | #1 |
Find the pressure at the center of a planet 2. Relevant equations dP/dr = -ρg (Hydrostatic Equilibrium) g = GM/r2 (acceleration due to gravity) 3. The attempt at a solution dP/dr = -ρg Assume that density is constant. subsitute GM/r2 for g in the pressure gradient formula dP/dr = -ρGM/r2 Now we need Mass as a function of radius. Divide the planet up into differential concentric rings then the differential mass element is related to the surface area. dM = 4πr2ρdr or dM/dr = 4πr2ρ (conservation of mass) Then integrating both sides of the the above equation gives. ∫dM = ∫4πr2ρdr M(r) = ∫4πr2ρdr With limits of integration from 0 to r and since density is constant M(r) = 4/3πr3ρ so the pressure gradient with a constant density gives dP/dr = (-ρg/r2)(4/3πr3ρ) Solving the differential equation for P gives ∫dP = ∫-(4πGρ2rdr)/3 with limits of integration from r1 to r2 (radius) and P1 to P2 (pressure) gives: P2-P1 = (-4Gπρ2/3)(r22-r12/2) Solving for P1 gives P1 = P2+(-2Gπρ2/3)(r22-r12/2) Setting the boundry condition as r2 = R1 and P2=0 gives the final equation for Pressure as a function of radius inside the planet with density ρ, planetary radius R and varying radius r as P(r) = (2πGρ2R2/3)(1-r2/R2) Is this correct? Does this mean that inserting 0 for r will give you (1-0) or just 1 and then the pressure at the center of the planet is dependent on just the density of the planet and the radius of the planet? |
| Dec10-08, 04:49 AM | #2 |
Mentor
| Dec10-08, 10:59 PM | #3 |
Yes, I am aware that it is a highly unrealistic assumption, but on my homework problem It gives me the question to simply find the pressure at the center of Saturn and Uranus. It gives no density function to integrate. The more difficult problems give you density functions to integrate. I just wanted to see if I had carried out the derivation correctly. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Pressure at the center of a planet
| Pressure at center of planet | General Astronomy | 7 | ||
| satellite question. find mass of planet and weight on planet? | Introductory Physics Homework | 2 | ||
| Center of pressure problem | Mechanical Engineering | 4 | ||
| Pressure at center of earth (or any planet) | Introductory Physics Homework | 0 | ||
| The center of Mass perfectly match the center of Force-> | General Physics | 9 | ||
