Pulsing a diode laser with very long pulses and very low repetition rates
  • Thread starter Thread starter r_daniel
    Diode Laser
r_daniel
Greetings,
I am an electronic engineer doing some research on high power laser diodes.
The problem I try to solve needs ~2300W of optical peak power coming from a high power laser diode.
The pulses must be with very long (30ms) at very low repetition rates (2Hz).
So,the duty cycle is DC = 0.06.
The calculations I do with the above parameters yield an average power
Pav= Ppeak x DC = 2300 x 0.06 = 138W.
Now the confusing part:
I have been told that the "average optical power" is not equal with the "optical power in CW mode" for very long pulses and very low repetition rates.
Hence, I can not use a laser diode which has 140W optical power in CW mode to get the needed ~2300W peak power.
Is that true ? Why ?
Are there any formulas that I can use to do the calculations for very long pulses to drive a laser diode ?
Any suggested books to read would be greate help..
Best Regards
chris
The reason that average pulsed power and CW power aren't necessarily the same is that when you first turn on a laser, you get better performance out of it for a brief time. Assuming that current injection happens quickly, the population inversion is larger than the threshold value for a brief time (as the photon density hasn't yet had time to build up), and the device is also at a lower temperature than when it has been on for a long time. So, if you imagine pulsing a laser as a series of turning a laser on, turning it off again, and letting it cool off before turning it on again, then it should be clear that average pulsed power is higher than CW power.
But at the long timescales we're talking about (especially for diode lasers), any electronic effects will be washed out, and the only factor that matters is heating. What matters is whether your laser has time to cool off between pulses, and ultimately, that depends on how well heat sunk it is.
Thanks for the answer..
So, the needed optical peak power will depend on, if the diode has the time to be cooled enough between the pulses..
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In her YouTube video Bell’s Theorem Experiments on Entangled Photons, Dr. Fugate shows how polarization-entangled photons violate Bell’s inequality. In this Insight, I will use quantum information theory to explain why such entangled photon-polarization qubits violate the version of Bell’s inequality due to John Clauser, Michael Horne, Abner Shimony, and Richard Holt known as the...
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I am not sure if this falls under classical physics or quantum physics or somewhere else (so feel free to put it in the right section), but is there any micro state of the universe one can think of which if evolved under the current laws of nature, inevitably results in outcomes such as a table levitating? That example is just a random one I decided to choose but I'm really asking about any event that would seem like a "miracle" to the ordinary person (i.e. any event that doesn't seem to...
