Energy Required to Vaporize Methanol
  • Thread starter Thread starter jjackson927
    Energy Methanol
The discussion centers on calculating the energy required to vaporize methanol for a production lab design. The formula presented includes both the specific heat capacity (CP) and the latent heat of vaporization, but the user is unsure how to account for the variation of CP with temperature. A suggested approach is to use a spreadsheet to calculate energy for small incremental temperature increases, adjusting CP values accordingly. Alternatively, for simplicity, one could use the maximum CP value since methanol's boiling point is relatively low at around 60°C. Accurate calculations depend on the desired precision for the lab's heating requirements.
jjackson927
I apologize for the fact that I am a complete layman. It might be time for me to go and learn some thermodynamics.
I am working on the design for a production lab at my Community College, and while I'm sure we have engineers to do this for us, I was really curious about sizing a boiler. I will not be heating methanol alone, I think if I can understand the process, then I can do the rest.
I do believe there are 2 terms in the problem.
Q=CP (kJ/kg) * m *\DeltaT + Latent heat of Vaporization (kJ/kG)*m
Am I missing anything here? My question is, how do I account for that fact that the CP changes with the temperature of the medium? I have a background in Calculus and Diff Eq, with one semester of Physics (Calculus based mechanics), I'm just not sure what to do here.
Here are a couple of links for methanol properties:
http://www.engineeringtoolbox.com/methanol-properties-d_1209.html
http://www.google.com/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.methanex.com%2Fproducts%2Fdocuments%2FTISH_english.pdf&ei=BmaDSe6tCd-Btwe9xbHICQ&usg=AFQjCNE2IumqcN455h4Lte2Id0rfFRRIXQ&sig2=ClwRe8q3jLPB9j2aQp29rA
The easy way that works pretty well is to use a spreadsheet and calculate the energy required for small incremental temperature increase steps. Then you can use the referenced chart and adjust the Cp value as you increase temperature. To get the total you sum up the incremental changes.
Honestly, since the boiling point is only around 60°C, I'd seriously consider just using the max value and treat it as a constant. I guess it just depends on what kind of accuracy you are looking for. Also, don't forget, the Cp value is at a constant pressure.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
9K
