Thread Closed
Potential inside a grounded spherical conducting shell due to point dipole
Share Thread Thread Tools
Feb10-09, 10:32 AM   #1
Suppose a point dipole is located at the centre of a grounded spherical conducting shell. Find the potential and electric field at points inside the shell. (Hint: Use zonal harmonics that are regular at the origin to satisfy the boundary conditions on the shell.)
2. Relevant equations
since the metal is grounded then only negative charges are left on the surface.
V(r)=[tex]\frac{1}{4\pi\epsilon}[/tex][tex]\sum\frac{q}{r}[/tex]
3. The attempt at a solution
i'm not sure the effect of spherical shell on the potential at any points inside the points, anyone can offer some insight thanks?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb10-09, 11:06 AM   #2
Recognitions:
Homework Helper Homework Help
You seem to be attempting to use Coulomb's law; but that is a bad idea. The dipole will induce some unknown charge density onto the shell...correct? How can you possibly use Coulomb's law when you don't know what that charge density is?
Instead, use the hint provided. Where does the potential obey Laplace's equation? What is the general solution to Laplace's equation using spherical harmonics? Think of appropriate boundary conditions and apply them to that solution.
Feb11-09, 01:54 AM   #3
well, i just informed by professor the point dipole at the origin will have the potential of [tex]\frac{1}{4\pi\epsilon}\frac{p*cos\theta}{r^{2}}[/tex] inside the sphere (p=dipole moment).
the boundary condition at the shell is V=0. and i need 1 more boundary condition to solve the laplace equation, which in this case is the solution is of the form, ([tex]A*_{l}r^{l}+\frac{B_{l}}{r^{l+1}}[/tex]) [tex]P_{l}*cos\theta[/tex]. (the latex has some problem, but the way the theta term in denominator is not meant to be there ad should be shifted outside to be the nominator) just not sure what is the next boundary condition as i cant choose r=0 as the potential fx will blow up. any ideas how to kick start the next step, thanks
Feb11-09, 02:36 AM   #4
Recognitions:
Gold Membership Gold Member
I don't know if this helps but consider that since the shell is conducting and grounded the field outside should be zero as should be the potential. Thus the superposition of the fields due to the charge distribution on the sphere and the dipole inside should cancel outside the sphere.
You don't need to solve for the charge distribution on the sphere explicitly you need only determine the component of the potential it must be producing to cancel the potential of the dipole. You can then use the fact that the potentials of both sphere and internal dipole must tend to zero at r->infinity. [Edit: Correction! Not necessarily the potentials but the fields i.e. gradient of the potentials must approach 0 at r->infinity.]
Feb11-09, 07:55 AM   #5
Recognitions:
Quote by JayKo View Post
Would the potential blow up at the origin if there was no dipole there? If not, then the blow up at the origin is due entirely to the dipole potential and so you can say that the potential due to just the shell must be of the form:
[tex]V(r,\theta)=\sum_{l=0}^{\infty}A_l r^l P_l (\cos\theta)[/tex]
And so the potential due to the shell and the dipole is of the form:
[tex]V(r,\theta)=\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{r^{2}}+\sum_{l= 0}^{\infty}A_l r^l P_l (\cos\theta)[/tex]
Feb11-09, 08:33 AM   #6
Quote by gabbagabbahey View Post
thanks for the help.
potential at the origin is zero if no dipole, i supposed.
good reasons, but here comes the questions.
since the potential is of the function (radius,theta) we need 4 equations (boundary conditions), and what would that be? the only condition i know off is r=R (at the shell) V=0.
Feb11-09, 08:43 AM   #7
Recognitions:
Really? Why would you need 4 BCs?
The general solution only has 2 unknown constants [itex]A_l[/itex] and [itex]B_l[/itex] (Which is the way it should be since it is the solution to a 2nd order differential equation!)
The fact that the potential due to the shell is bounded at r=0 allowed you to determine the [itex]B_l[/itex] values.
Now just apply the other boundary condition [tex]V(r=R,\theta)=0[/itex] to find the [itex]A_l[/itex] values.
Feb11-09, 08:46 AM   #8
Quote by jambaugh View Post
i see, well, is it possible to assume r->infinity, V=0. for the dipole? as i need to establish the boundary condition to solve for the coefficient of A.thanks
[you need only determine the component of the potential it must be producing to cancel the potential of the dipole] how do i determine the potential of the shell itself? assuming i get your meaning.
Feb11-09, 08:52 AM   #9
wait, i don't get it. [tex]A*_{l}r^{l}+\frac{B_{l}}{r^{l+1}} [/tex] you see, when r=0, the terms blow up. anything to the power of zero is still zero.how to determine [tex]B_l[/tex] ?
Feb11-09, 08:53 AM   #10
Recognitions:
The solution [tex]V(r,\theta)=\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{r^{2}}+\sum_{l= 0}^{\infty}A_l r^l P_l (\cos\theta)[/tex] is only valid inside the sphere; the boundaries are therefor at r=0 and r=R not r=infinity.
In order to find the [itex]A_l[/itex]'s apply the condition at the shell [tex]V(r=R,\theta)=0[/tex]. You still haven't actually used that condition!
Feb11-09, 09:03 AM   #11
oh i see, i m left with determining the coefficient, [itex]A_l[/itex]. i suppose the method is called fourier trick by david griffith? right?
which means
[tex]\sum_{l=0}^{\infty}A_l r^l P_l (\cos\theta)=-\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{r^{2}}[/tex]
and then multiply both sides by sin(theta)? and integrate it
Feb11-09, 09:06 AM   #12
Recognitions:
All the [itex]B_l[/itex]s must be zero except for [itex]B_1[/itex]---which corresponds to the potential of the dipole which is the only contribution which should be allowed to "blow up" at the origin. If any of the other [itex]B_l[/itex]s were non-zero, you would have other terms where you end up dividing by zero at the origin.
The reason why the [itex]B_1[/itex] term corresponds to the dipole, is because of the form of the potential of the dipole
[tex]V_{dip}=\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{r^{2}}=\frac{1}{4\p i\epsilon_0}\frac{p*P_1(\cos\theta)}{r^{1+1}}\implies B_1=\frac{p}{4\pi\epsilon_0}[/tex]
Feb11-09, 09:10 AM   #13
Recognitions:
Sort of, one method is to use a "Legendre trick" and multiply each side of the equation by [tex]P_m(\cos\theta)\sin\theta d\theta[/tex] and integrate from 0 to pi.
But a much easier method is to notice that [tex]\cos\theta=P_1(\cos\theta)[/tex] and simply compare coeffecients.
Feb11-09, 09:12 AM   #14
Recognitions:
which means
You mean:
[tex]\sum_{l=0}^{\infty}A_l R^l P_l (\cos\theta)=-\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{R^{2}}[/tex]
where capital R is the radius of the shell, right?
Feb11-09, 09:19 AM   #15
how you come about this equation?[tex]V_{dip}=\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{r^{2}}=\frac{1}{4\p i\epsilon_0}\frac{p*P_1(\cos\theta)}{r^{1+1}}[/tex]
this is from the [itex]B_l[/itex] term, i got it now. thanks
it should be this right?
[tex]V_{dip}=\frac{1}{4\pi\epsilon_0}\frac{p*\cos\theta}{r^{2}}=\frac{B_L*p* P_1(\cos\theta)}{r^{1+1}}[/tex]
hence comparing it and we get [itex]=B_l=\frac{p}{P_l*4*pi*epsilon}[/itex]
Feb11-09, 09:26 AM   #16
Recognitions:
i dont get it, as it is not the form of zonal harmonic. why?
It is exactly in the form of a zonal harmonic....
What is [tex]\frac{B_1}{r^{1+1}}P_1(\cos\theta)[/tex] if [tex]B_1=\frac{p}{4\pi\epsilon_0}[/tex]?
What is [tex]\sum_{l=0}^{\infty}\frac{B_l}{r^{l+1}}P_l(\cos\theta)[/tex] if [tex]B_l=\left\{ \begin{array}{lr} 0, & l\neq1\\ \frac{p}{4\pi\epsilon_0}, & l=1\end{array}[/tex]?
How is that not in the form of a zonal harmonic?
Feb11-09, 09:31 AM   #17
here why [tex]P_1=1[/itex]? isn't it = r?
Thread Closed
Thread Tools
Similar Threads for: Potential inside a grounded spherical conducting shell due to point dipole
Thread Forum Replies
Gauss: Conducting Spherical Shell w/ Point Charge Introductory Physics Homework 1
Potential inside (and outside) a charged spherical shell Advanced Physics Homework 5
Spherical conducting shell Introductory Physics Homework 8
Little question on the potential in a conducting spherical shell Introductory Physics Homework 2
Conducting sphere in a conducting spherical shell Introductory Physics Homework 2
