What are the Practical Uses of Oldham Couplers in Various Machines?
  • Thread starter Thread starter farhad_mech
    Coupling
Oldham couplers are primarily used to connect parallel shafts that may experience misalignment, particularly in applications like CNC machines and pump systems. Despite being considered less practical today due to frictional losses and better alternatives, they are still utilized in specific scenarios, such as coupling electric motors to centrifugal pumps. The design allows for some misalignment, reducing excessive loads on bearings, which can prolong their lifespan. Users have noted that while they may not be as common in modern machinery, Oldham couplers remain relevant in certain applications. Overall, they serve a critical function in maintaining operational efficiency in machines requiring shaft alignment flexibility.
farhad_mech
hello
our prof talked about oldham coupler and showed us some animations of how it works,
but didn't mention about where and in which machines it is is used,
anybody knows some practical uses of oldham coupler and some examples
of machines this coupler is used in?
thanks
its an oldie. it works in labs now.lolz...
Practical use? What do you observe when you see it? Its a coupling for parallel shafts at some radial distance
thanks for answer.i know "Its a coupling for parallel shafts at some radial distance",i want to know name of some machines that use it,searching in google i found that it is used in cnc machines,is there any specific other machines that use this couplig?
you said it works in labs now,you mean toadays oldham coupler is not used anymore?
:frown:can you show us a link?
I won't say anymore, but I haven't seen it so far other than my kinematics lab as an inversion of a 4 bar chain.
It isn't practical anymore for today's world. First, its a lower pair, has sooo much frictional loss, second, it is suitable for very small radial distances, there are better(efficient as well as cheap) options.
These couplers are used all over, especially in pump applications.
Look at companys like Lovejoy.
I'd have to disagree with that. They're used extensively for coupling electric motors to pumps, especially centrifugal pumps. I use a type of this coupling for connecting the drive shafts of two pumps together, so there are a lot of uses.
Generally, they're used when there are two shafts that need to be connected, and the shafts are both fully supported by bearings. If the shafts were directly coupled (ie: locked together as a single shaft) then any misalignment would create huge loads on the bearings which would wear out prematurely. So the coupling allows for some misalignment between fixed shafts so there won't be excessive loads created on the bearings.
hmm, nice solution. :smile:
thank you so much Q_Goest and FredGarvin,i think i have my answer now.
yeah me too, thanks q_goest & fred
