Why do I feel differently when standing in 90 degree air vs water?
The discussion revolves around the differing sensations of temperature experienced when standing in 90-degree air versus 90-degree water. Participants explore the physical principles underlying these sensations, including heat transfer, thermal conductivity, and specific heat capacity, without reaching a consensus on the primary reasons for the differences in perception.
  • Some participants suggest that the evaporation of water from the skin contributes to a cooling effect, which may explain the differing sensations.
  • One participant cites the high specific heat capacity of water, arguing that it absorbs more heat from the body compared to air, leading to a cooler feeling.
  • Another point raised is that water's higher thermal conductivity allows heat to transfer more efficiently from the body to the water than to the air.
  • It is noted that water is denser than air, which means there is more water in contact with the skin, potentially enhancing the cooling effect.
  • Participants discuss the dynamic nature of water, which is constantly being replaced, as a factor that contributes to the sensation of coolness compared to static air.
  • One participant emphasizes that skin temperature is lower than body temperature, and that the heat transfer dynamics differ significantly between air and water.
  • A mathematical expression for heat loss is provided, highlighting that the convection heat transfer coefficient is much larger in water than in air, affecting heat loss rates.
Participants express various viewpoints on the reasons for the differing sensations, with no clear consensus reached. Multiple factors are proposed, and the discussion remains open-ended regarding the primary influences.
Some assumptions about the conditions of the experiment, such as the uniformity of temperature and the specific heat capacities of air and water, are not explicitly stated. The discussion also does not resolve the complexities of heat transfer dynamics in different mediums.
Bryan1108
This is just asilly question that somebody asked and it was fun because a dozen different intelligent men hemmed and hawed about it and gave some truly silly answers. I kind of want to see how this board does with it.
If I am standing around and the temperature of the air is 90 degrees, then I feel hot and sweat. If I take a shower and the temerature of the water is 90 degrees, I feel cool and shiver. Why?
Part of the answer may be that the shower water on your skin is evaporating, which has a cooling effect.
From http://en.wikipedia.org/wiki/Water_(molecule)#Heat_capacity_and_heats_of_vaporization_and_fusion":
"Water has the second highest specific heat capacity of any known chemical compound"
This means it takes more heat energy from your body to raise the temperature of water to equal your body temperature, compared to air. Also water's thermal conductivity is higher than air's (0.6 vs 0.025 W/(m·K)), which means heat moves easier to water. In simpler terms water can absorb more heat from you, and do it faster than air, thus leaving you with less heat, and feeling colder.
Edit: Two more factors just popped into my head. First at these temperatures water is liquid and air is a gas. Therefore, water will be more dense than air, meaning there will simply be more of it close to you. Secondly air will be fairly static, whereas water will be pulled by gravity and only in contact for a few seconds before going down the drain (along with the heat you gave it), and being replaced with new water not yet warmed by you.
So we have a combination of water having a higher heat capacity, higher thermal conductivity, higher density, and being constantly moving. There is more of the water, which absorbs heat faster, and absorbs more before reaching equilibrium, and it is constantly being replaced by fresh unwarmed water. It's a wonder we don't get hypothermia in the shower.
Well that's where the OP leads us: we would get hypothermia in the shower if the water temperature were much cooler than body temperature. That's why you want it warmer!
Skin temperature is less than body temperature, and the skin releases heat into the air as part of internal temperature regulation. Since air has a much lower rate of heat capacity than water, the comfort zone for air is lower wider than it is for water.
http://www.wonderquest.com/skin-temperature.htm
The amount of heat your body loses to the environment is Q=H*A*deltaT, where H is the convection heat transfer coefficient, A is the surface area, and deltaT is the temperature difference between your skin temperature and the water/air temperature. For the same temperature difference you will lose much more heat in water then in air because the heat transfer coefficient in water is much much bigger then in air. If your skin temperature is 90 and the water/air temperature is also 90, deltaT=0 and you won't lose heat (by convection).
15K
9K
