Solving Analytic Function: F(x) Expression
  • Thread starter Thread starter asi123
    Function
The discussion revolves around the existence of an analytic function F(x) that satisfies a specific expression related to integration and logarithmic functions. Participants are exploring the properties of analytic functions and the implications of integration techniques.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss integration techniques, particularly substitution, and question the implications of using logarithmic functions in defining analytic functions. There is a focus on the continuity and analyticity of the logarithm in relation to specific points in the complex plane.
The discussion is active, with participants raising questions about the continuity of the logarithmic function and its implications for analyticity. Some guidance has been offered regarding the nature of the antiderivative and its relation to known problems in complex analysis.
There are constraints regarding the definition of the logarithmic function and its behavior around certain points in the complex plane, particularly concerning the negative x-axis and points +/-2i.
asi123
Hey guys.
I'm pretty much stuck on this one.
The question is, is there an analytic function F(x) which fulfill the expression in the pic? (I'm sure I messed up the English, sorry :confused:)
Thanks
Integrate by letting u= z2+ 4.
I need to Integrate this thing in order to find the function?
What do you mean by "letting u= z2+ 4"?
Thanks a lot.
Thanks a lot.
Integration by substitution?
Oh, ok so I got half Ln of something, is that the function? seems too easy...
Thanks a lot.
But does log(z^2+4) define an analytic function on the plane minus those two points? Can you pick values of the log that make it continuous everywhere? What happens with the 'function' log(z) as you move in a circle around the origin?
Yeah right, it's not analytic unless you take off the entire x negative axis.
So does that mean that such analytic function does not exist?
Thanks a lot.
Thanks a lot.
That's the general picture, yes. You can write the antiderivative as log(z+2i)+log(z-2i). You have exactly the same kind of problem as log(z) has around the points +/-2i.
Ok, Thanks.
  • · Replies 16 ·
