Thread Closed
Set-up time in digital circuits
Share Thread Thread Tools
Mar10-09, 03:52 PM   #1
Why should the input in any logic be present before the clock?
Is the setup time related to clock rise time?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Mar11-09, 02:53 PM   #2
Recognitions:
Precisely. You want the inputs to be stable before a clock transition in order to ensure that you're reading the right value, and not the previous value, or possibly even worse, some transition value between the two. Why do they say that a value should be stable for X nanoseconds before the clock? Probably because of how things are arranged internally and how they propagate. That or they ran some tests and that was the minimum value that did not result in errors.
Mar11-09, 11:35 PM   #3
Quote by MATLABdude View Post
ok. thanks. A year ago, I was trying to use the same signal for clock and data in, it worked in simulator but did not work in the ckt. I had to delay the clock.
The rise time at the data in and the clock must be different. If they are same, my ckt should have worked.
Mar11-09, 11:48 PM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
It's actually not generally related to the clock rise time, because gates are designed to very rapidly change state at a specific trigger voltage. Whether you arrive at that voltage quickly or slowly, the change in state happens with the same quickness.
The setup time is for charging the capacitance of the transistors inside the gate. Even after maximal voltage has been attained at the gate's input, the transistor gates, junction capacitances, etc. within still must be charged. The amount of time needed to guarantee that the gate reacts properly is called the setup time.
Quite often, gates can be specifically designed to have zero setup time.
- Warren
Thread Closed
Thread Tools
Similar Threads for: Set-up time in digital circuits
Thread Forum Replies
Digital logic circuits material Electrical Engineering 2
Digital read out of air pressure over time... Mechanical Engineering 26
RC Circuits & Time Constant Measurement Introductory Physics Homework 0
time constants, resistance and RC circuits Introductory Physics Homework 2
online books on digital integrated circuits Electrical Engineering 0
