Thread Closed
Two body problem
Share Thread
Mar27-09, 05:48 AM   #1
Two body problem
Two gravitating particles with masses m1 and m2 start from rest a large distance apart. They are allowed to fall freely towards one another. The particles are given equal and opposite impulses I when they are a distance a apart, such that each impulse is perpendicular to the direction of motion.
Show that the total angular momentum of the two particles about their centre of mass has magnitude aI /µ, where µ is the reduced mass of the system.
2. Relevant equations
Reduced mass=m1m2/(m1+m2)
3. The attempt at a solution
Well this is the second last part of quite a long question on the 2-body problem, and I've managed fine until now (showing the position of the centre of mass 'C' - is constant, finding their relative speed etc) but I'm not sure how to go about this part of the question. The two particles are going to be moving in a straight line towards each other before the impulses which should mean 0 angular momentum before, so then the only angular momentum afterwards would be that from the impulses right?
But the impulses are perpendicular to the direction of motion so with the r x p cross product we'd just have angular momentum=dist. from C * impulse in each case wouldn't we? The m2 mass particle should have a distance (m1/(m1+m2))a from C and the m1 particle a distance of (m2/(m1+m2))a, but then clearly I've done something wrong because the sum of the impulses will just be (m1+m2/m1+m2)aI=aI.
Where am I going wrong? Thanks!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar27-09, 08:25 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
That sure seems correct to me. aI/mu doesn't even have the correct units, does it?
Mar27-09, 09:06 AM   #3
Actually that's a fair point, whereas aI does - weird! I'll check with someone else to see if the question is mistyped, but it seems odd that the entire "/µ, where µ is the reduced mass of the system." would be a mistake...
I'll let you know if i find out! Do you think just aI is the correct answer then?
Thread Closed
Similar discussions for: Two body problem
Thread Forum Replies
three body problem!!!! Classical Physics 0
3 body problem in 1D Advanced Physics Homework 0
two body problem in Gr Special & General Relativity 5
the Three Body Problem Classical Physics 11
Three body problem Astrophysics 1
