Is it possible to break a circuit electronically?
  • Thread starter Thread starter U4edot
    Break Circuit
It is possible to electronically break a circuit using logic circuits, depending on the definition of "break." Multiplexers (MUXes) can route logic signals, while logic gates can enable or disable signals. Tri-State output gates can also control signal flow. For AC current management, triacs are suitable, and optocouplers can allow isolated logic signals to trigger them. The discussion highlights various methods for integrating logic circuits with electrical components.
U4edot
I know you can use fueses, switches, and circuit breakers.
But is it possible to use a logic circuit to break a circuit path?
Sure. Depends on what you mean by "break", though. You can use multiplexers (MUXes) to select which logic signal you want to route into another circuit, for example. You can use logic gates to enable or disable a signal continuing on. You can use a Tri-State output gate to enable or disable a signal from continuing on...
Say I want to use a logic circuit to break the power supply of another electrical component.
OK, I read a bit on Wikipedia
Does anyone know if a demultiplexer can handle AC current?
There are triacs specifically designed to handle AC voltages and currents. There are optocouplers that permit using floating (electrically isolated) logic signals to trigger the triacs.
Thanks for the input I'll look at this when I get off work
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
