How Do You Calculate the Mass of an Aluminum Cup in a Heat Transfer Problem?
  • Thread starter Knfoster
  • Tags
    Mass
The cup loses heat by heating up from 21.2C to 25.7C; that heats up the water.The aluminum cup contains 217g of water at 21.2C, and a 404g sample of silver is placed in the water, which is at an initial temperature of 80.8C. A 41.0g copper stirrer is used to stir the mixture until it reaches its final equilibrium temperature of 25.7C. In summary, an aluminum cup with 217g of water at 21.2C is heated by a 404g sample of silver at an initial temperature of 80.8C and a 41.0g copper stirrer until reaching a
Knfoster
45
An aluminum cup contains 217g of water at 21.2oC. A 404g sample of silver at an initial temperature of 80.8oC is placed in the water. A 41.0g copper stirrer is used to stir the mixture until it reaches its final equilibrium temperature of 25.7oC. Calculate the mass of the aluminum cup.
Q=mCdeltaT
heat lost=heat gained
Could someone please help me set the problem up w/o numbers. Thanks.
You have the right equations to work with, maybe listing a few facts will help get you going:
Every object will end up at the final temperature of 25.7C.
Each object either loses heat, or gains heat. That tells you on which side of the heat lost=heat gained equation each object belongs.
Presumably the copper stirrer also starts out at 21.2C.
I would approach this problem by first identifying the known quantities and variables. In this case, we are given the mass of water (217g), the initial temperature of the silver (80.8oC), the final equilibrium temperature (25.7oC), and the mass of the copper stirrer (41.0g). The unknown variable is the mass of the aluminum cup.
Next, I would use the heat equation Q=mCdeltaT to calculate the heat lost by the silver and the heat gained by the water. Since the system is in equilibrium, these two values should be equal. This will allow us to set up an equation and solve for the unknown mass of aluminum.
Finally, I would plug in the given numbers and solve for the mass of the aluminum cup. This will give us the final answer and complete the problem. It is important to remember to use the correct units and to pay attention to the signs of the values (i.e. negative for heat lost and positive for heat gained).
FAQ: How Do You Calculate the Mass of an Aluminum Cup in a Heat Transfer Problem?
1. What is the equation for calculating mass using Q=m*C*delta T?
The equation for calculating mass using Q=m*C*delta T is Q (heat energy) = mass * specific heat capacity * change in temperature.
2. What is the specific heat capacity represented by "C" in the equation?
The specific heat capacity, represented by "C" in the equation, is the amount of heat energy required to raise the temperature of 1 gram of a substance by 1 degree Celsius.
3. How does the change in temperature affect the calculated mass?
The change in temperature has a direct effect on the calculated mass. As the change in temperature increases, the mass will decrease and as the change in temperature decreases, the mass will increase.
4. Can this equation be used for all substances?
Yes, this equation can be used for all substances. However, the specific heat capacity will vary depending on the substance, as different substances require different amounts of heat energy to change its temperature.
5. What are the units used for each variable in the equation?
The units used for each variable in the equation are:
- Q (heat energy) is measured in Joules (J)
- Mass is measured in grams (g)
- Specific heat capacity is measured in Joules per gram per degree Celsius (J/g°C)
- Change in temperature is measured in degrees Celsius (°C)
