| Thread Closed |
Force on wire due to magnetic field |
Share Thread | Thread Tools |
| Apr30-09, 10:54 AM | #1 |
A straight segment of a current-carrying wire has a current element IL where I = 2.70 A and L = 2.60 cm i + 4.40 cm j. The segment is in a region with a uniform magnetic field given by 1.36 T i. Find the force on the segment of wire. (Give the x, y, and z components.) 2. Relevant equations [tex]\theta = tan^{-1}(y/x)[/tex] [tex]F = ILBsin\theta[/tex] 3. The attempt at a solution Well I am pretty sure there will be no x or y component because the force will be perpendicular in the z direction. To find the z component I found the angle between the wire and the mag field using: [tex]tan^{-1}(4.4/2.6) = 59.421[/tex] After that I thought you are just supposed to plug everything in: [tex]2.7A * .05111m * 1.36 * sin(59.421) = .1615N[/tex] But it's wrong!! I'm not sure what I am doing wrong, the book I am using isn't very good ad explaining. I'm sure it's something simple that I am just overlooking. Thanks, Nick 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Force on wire due to magnetic field
| Wire Loops, Current, Magnetic Field, & Straight Wire HELP! | Introductory Physics Homework | 1 | ||
| Force of wire in a magnetic field | Introductory Physics Homework | 2 | ||
| force, magnetic field, current, long straight wire | Advanced Physics Homework | 3 | ||
| Force Due to Magnetic Field on a Charge Carrying Wire | Advanced Physics Homework | 2 | ||
| Wire in a magnetic field | General Physics | 11 | ||
