Thread Closed
A safe held by a string breaks and lands on a spring
Share Thread Thread Tools
May26-09, 05:39 PM   #1
A 1209 kg safe is 1.54 m above a heavy-duty spring when the rope holding the safe breaks. Thr safe hits the spring and compress it 53 cm. What is he spring constant of the spring?
2. Relevant equations
K=mV^2/2
U=mgh
Ki+Ui=Kf+Uf
3. The attempt at a solution
I thought I understood momentuem and energy but not anymore. Here is what I did....
Ui=mgh= 2*9.8*1.54
Kf=mV^2/2
Then solved for V and got 5.494 m/s
Then used that velocity for the spring constant by using......
U=k(delta x)^2/2
K=mV^2/2
then solved for k and got 129912 N/m...... but that is coming up wrong what am i doing wrong.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May26-09, 06:28 PM   #2
any ideas?
May26-09, 06:33 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Well for one thing you are using m = 2 kg when it is given that m = 1209 kg. Then you neglect the gravitational potential energy in the 2nd set of equations. It is better to do this all in one step: Initial energy = Final energy, where v_initial = v_final = 0.
May26-09, 06:34 PM   #4
Recognitions:
Hi talaroue!
(try using the X2 and X2 tags just above the Reply box )
Quote by talaroue View Post
Ui=mgh= 2*9.8*1.54
No, the safe stops moving 53cm lower.
May26-09, 06:36 PM   #5
JAY:
so your saying that i should just use U=mgh and U=k(delta x)^2/2....solve for k and get....
k=2mgh/delta x^2
TINY TIM:
so I didn't go about the problem wrong I just have to add the .53 m to the hieght?
May26-09, 06:42 PM   #6
Admin
The safe starts 1.54 m (154 cm) above the spring and then travels another 0.53 m after contact. That must be considered with respect to gravitational potential energy.
May26-09, 06:46 PM   #7
Recognitions:
JAMES:
k=2mgh/delta x^2
Yes, but 'h' is as noted by others, and don't forget to correct your value of 'm'.
May26-09, 06:47 PM   #8
ahhh I see at least I had the right idea just need to be more careful. If you guys don't mind I am having problems with another problem as well.... it might be a same problem i am going to go back and look at it but I made a thread about it as well....
Second problem I have issues with
May26-09, 06:50 PM   #9
Quote by PhanthomJay View Post
I wasn't using 2 as my m, that was just noting the second equation is U=k(delta x^2)/2 I didn't combined them when i posted that, i see what you are saying though.
Thread Closed
Thread Tools
Similar Threads for: A safe held by a string breaks and lands on a spring
Thread Forum Replies
Block held against a spring going up a frictionless plane Introductory Physics Homework 3
Tension in a String just before it breaks (Circular Motion) Introductory Physics Homework 4
[String-schools] Spring program in Italy Beyond the Standard Model 0
String Theory: Forever safe? Beyond the Standard Model 13
