Relationship between electric field intensity and potential
The discussion revolves around the relationship between electric field intensity and electric potential, specifically examining different expressions of this relationship and their implications. Participants explore both general and specific cases of the equations governing this relationship, touching on concepts from calculus and vector calculus.
  • One participant presents two expressions for the relationship between electric field intensity (E) and electric potential (V): E = -dV/dx and E = -Delta V/Delta x, explaining their applicability in different scenarios.
  • Another participant agrees with the initial understanding, suggesting that the original post does not contain obvious errors.
  • A later reply introduces a more general expression for the relationship, E = -∇V, stating that the previous equations are special cases, particularly relevant in introductory physics contexts.
  • Another participant challenges the assertion that the general expression is universally applicable, stating that it only holds for conservative electric fields and providing a more comprehensive equation that includes additional terms related to magnetic fields.
  • There is an acknowledgment of potential misinterpretation of language in the discussion, with participants clarifying their intentions and meanings.
Participants generally agree on the correctness of the initial expressions presented, but there is disagreement regarding the generality of the relationship and the completeness of the equations discussed. Multiple competing views remain regarding the applicability of different equations in various contexts.
Some limitations are noted, including the dependence on the assumption of conservative electric fields for certain equations and the potential misunderstanding of terminology used in the discussion.
kihr
I find that there are two ways in which the relationship between electric field intensity and potential are expressed as mentioned hereunder:
(A) E = - dV / dx (V = potential and x is the direction along which V varies)
(B) E = - Delta V / Delta x
My understanding of the application of (A) and (B) is as follows:
(A) is the general case where the variation of V with x could be linear or non-linear, i.e. E could be constant or variable along the x direction. E represents the limiting value of an incremental value of V divided by an incremental value of x (at a given value of x) as the increment in x is made infinitesimally small. Thus E is the gradient of the V versus x graph at any given value of x.
(B) is a specific case of (A) when V varies linearly with x, when E is constant along
the x direction. In this case the value of E would be the same irrespective of the
values chosen for Delta V or Delta x.
I would appreciate if the above understanding could be commented upon / ratified. Thanks.
Looks like you understand things to me.
I am sorry if I have offended you in any way by my query. I genuinely request for a confirmation that my understanding is correct. Kindly advise. Thanks.
I doubt very much that you offended Doc Al. My interpretation of his post was that he was merely stating in a very succinct way that your original post looked correct and didn't contain any obvious errors. If it did, I'm almost certain he would have pointed them out. Perhaps with the following edits the meaning (as I understood it) becomes clearer: "[It] [l]ooks like you understand things [just fine] to me."
The only thing I would add to your post is that the most general statement of the relationship between the electric field and the electric potential is:
[tex]\mathbf{E}=-\nabla V[/tex]​
The other two equations are merely special cases of it, the second being common in introductory physics when students are not expected to have a grasp of vector calculus (or perhaps calculus of any kind)
Your analysis of things is correct, kihr.
Thanks very much. Looks like I had goofed up with my interpretation of the English language!
This is NOT the most general relation. This only holds in the special case for conservative E fields. The more general expression is:
E = -grad V - dA/dt + (u X B).
A = magnetic vector potential, u = velocity, B = magnetic flux density.
Also, V = integral {E*dl} along a path.
Claude
