How Can Hydrogen Gas Be Produced Cheaply and Safely?
  • Thread starter Thread starter Archaeanimus
    Hydrogen
The discussion focuses on methods for producing hydrogen gas (H2) cheaply and safely using an electrolytic cell powered by an A/C-D/C wall converter. The user is considering various electrolytes, including sulfuric acid (H2SO4), hydrochloric acid (HCl), potassium hydroxide (KOH), and sodium hydroxide (NaOH). The consensus suggests that sulfuric acid or sodium hydroxide are preferable due to their cost-effectiveness and lower risk of producing toxic gases. The user aims to avoid chlorine production and is interested in maximizing oxygen output during the process.
  • Understanding of electrolytic cells and their operation
  • Familiarity with chemical properties of sulfuric acid (H2SO4) and sodium hydroxide (NaOH)
  • Knowledge of electrolysis principles and voltage requirements
  • Basic chemistry knowledge regarding gas production and safety precautions
  • Research the electrolysis of water using sulfuric acid (H2SO4) as an electrolyte
  • Investigate the safety measures for handling sodium hydroxide (NaOH) in hydrogen production
  • Explore the efficiency of different electrolytes in hydrogen gas production
  • Learn about the environmental impact of using various electrolytes in electrolysis
Chemists, hobbyists in renewable energy, and anyone interested in safe and cost-effective hydrogen gas production methods.
Archaeanimus
I am trying to work out a method of producing hydrogen gas (H2) cheaply. What I have so far is an electrolytic cell with carbon electrodes from a dry-cell battery powered by an A/C-D/C wall converter with output from 1.5V to 12V. I plan on using distilled water, but I don't want to rely on the water self-ionizing to split the molecules as this would take a VERY long time. The electrolytes I've looked at so far are sulfuric acid (H2SO4), hydrochloric acid (HCl), potassium hydroxide (KOH), and sodium hydroxide (NaOH). I'd like to use something relatively cheap and unlikely to produce poisonous gases (ie, Cl2) and production of oxygen would be a plus. Any suggestions?
Chemistry news on Phys.org
Go for sulfuric acid or one of hydroxides. HCl is out of the question.
If you start with NaCl you will initially get some chlorine, later you will be left with just a hydroxide solution.
If you start with HCl, once all chlorine is removed from the solution, you are left with just pure water.
Thanks, I figured HCl might do that.
Sulfuric acid (I believe) will produce peroxodisulfate ions at less than 1V, but electrolysis of water takes at least 1.23V.
I know KOH is used in the extraction of heavy water, but I don't know what else it produces, if anything. If I do decide on the hydroxide, though, I think I'll use NaOH because the chemical properties are similar and it's a bit cheaper.
9K
55K
