Graph of a sinusoidal wave at a fixed position
The discussion centers on graphing the displacement of a sound wave described by the equation D(y,t) = (0.02mm)sin[(8.96 rad/m)y + (3140 rad/s)t + pi/4 rad] at a fixed position of y = 1.00 m over the time interval from 0 to 4 ms. Participants clarify that substituting y = 1.00 m into the equation is essential for generating the correct graph. The confusion arises from not calculating intermediate points between the ticks on the graph, which is crucial for accuracy. Ultimately, the correct approach involves evaluating the sine function at multiple time intervals to capture the wave's behavior accurately.
  • Understanding of sinusoidal functions and their properties
  • Familiarity with wave equations and their parameters
  • Basic graphing skills, particularly for trigonometric functions
  • Knowledge of units in physics, specifically converting millimeters to meters
  • Learn how to calculate intermediate values for sinusoidal functions
  • Study the impact of phase shifts in wave equations
  • Explore graphing software tools for visualizing waveforms
  • Investigate the relationship between frequency, wavelength, and wave speed
Students in physics or engineering courses, educators teaching wave mechanics, and anyone interested in understanding sound wave behavior and graphing techniques.
MyNewPony
A sound wave is described by D(y,t) = (0.02mm)sin[(8.96 rad/m)y + (3140 rad/s)t + pi/4 rad)], where y is in metres, and t is in seconds.
Draw a displacement-versus-time graph D(y=1.00m,t) at y= 1.00 m from t= 0 s and t= 4 ms.
I tried doing the graph (see figure attached), but apparently it's wrong. By 'fixed' position, it means that I must plug in 1.00 m into y for the entire time interval (0 to 4ms), correct? If that's the case, then all the points on the graph should be right. Can someone explain what I'm doing incorrectly?
Ah, my bad. I jumped the gun and skipped the points in between each tick.
I got the same graph as you did. How did you figure out how to get the points in between the points you already have on your graph? Because when I plug in y=1 into the equation, I don't get the right answer.
  • · Replies 26 ·
