Induced charge in conducting plate
In the scenario of a conducting plate positioned at the origin of the xy plane with a positive charge +q located at a distance d along the z-axis, the induced charge on the plate depends on its grounding status. If the plate is grounded, it will have an induced charge of -q, effectively neutralizing the influence of +q. Conversely, if the plate is isolated, no net charge will be induced, maintaining its original charge state. Charge distribution on the plate can be visualized through images, illustrating how the presence of +q affects the surface charge density. Understanding these principles is crucial for analyzing electrostatic interactions in conductive materials.
astro2cosmos
one conducting plate is at origin of xy plane. and +q is at distance of d from y-axis in the direction of z axis. then what is induced charge in conducting plate & how charge is distributed on plate?
What is the size of the plate?
If the plate is grounded, the induced charge is -q.
If it is isolated, no net charge can be induced.
You have to use images to get the charge distribution.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
