Numerical Methods: 3 Point Formula
The discussion focuses on the application of the 3-point formula for approximating the first derivative of a function, specifically in a Numerical Methods course. The user encountered a challenge in estimating the derivative at the fourth point due to the lack of subsequent values. The conversation highlights that while the 3-point formula typically requires values from both sides of the point in question, an alternative approach using a negative step size (h) can be considered for the first point, suggesting a potential workaround for the fourth point.
  • Understanding of Numerical Methods principles
  • Familiarity with derivative approximation techniques
  • Knowledge of 3-point formulas for derivative estimation
  • Basic calculus concepts, particularly limits and continuity
  • Research the application of the 3-point formula in various contexts
  • Explore alternative numerical methods for derivative approximation
  • Learn about finite difference methods and their variations
  • Investigate the implications of using negative step sizes in numerical analysis
Students in Numerical Methods courses, educators teaching calculus and numerical analysis, and professionals involved in computational mathematics or engineering applications.
bobmerhebi
Hello there,
I am taking a Numerical Methods course & i had a lecture today when we did an example on the 3-point formula to approximate the 1st derivative of f.
the example included 4 given x's with their images by f. & we had to get all the images for the 1st derivative of f.
so we used one of the two 3-point formulas to get the values for f' for each of the first 3 x's. the last x was left without an attempt to get its f'(x).
So tonight i was wondering about how could I apply the formula to get it & its seems that I can't, after all either of the 3 point formula's requires the values of either the previous & following x or the two values following x. In either cases that's not possible as there's is no value after this particular x.
my question is whether there's some kind of solution to this & if so or not how so ?
P.S. this is Not a HW question but rather a help in my lecture.
Thank you
To estimate f' for the 4th point, can't you use the same method as the 1st point? In other words, can't h be negative?
10K
