Spinning artificial gravity proof
The discussion centers on how artificial gravity in a spinning room works, particularly regarding the effects of jumping inside the wheel. When a person jumps, they will not land back in the same spot due to the Coriolis effect, which influences their trajectory. At the center of the wheel, centrifugal force is zero, meaning a person would float there, and jumping toward the center requires compensating for the wheel's rotational motion. The conversation emphasizes understanding the principles of centrifugal force and Newton's laws to grasp the mechanics of movement in a rotating reference frame. Overall, the physics behind artificial gravity can be demonstrated through experiments and theoretical explanations.
Mad_Eye
can someone explain to me how can it be proof that the spinning-room-artificial-gravity, actually works?
i mean, that if you take a huge wheel-like room, and spin it in the right velocity, the people inside will experience something that feels like gravity.
well, I've mange to understand that easily when one is standing.. but what about jumping for example? if the person inside is jumping up, will he land and the same spot (relatively to the wheel of course) he was jumping from?
embarrassing as it is, i didn't succeed to proof it (or deny it).
so if someone can show me how is it proofed, and also what happen if jumping over the center of the wheel, or exactly to the center of the wheel... i'd be glad
thank you very much :D
What do you mean by "proof" and "actually works"? Newtons laws and the http://en.wikipedia.org/wiki/Centrifugal_force_%28rotating_reference_frame%29" are well understood. You can do your own experiments.
No, the http://en.wikipedia.org/wiki/Coriolis_effect" will affect it. This happens on the rotating Earth too.
Well as you can see here:
http://en.wikipedia.org/wiki/Centrifugal_force_(rotating_reference_frame)
the centrifugal force is zero at the center and increases with distance to it. In the center you will float. If you jump to the center and have some speed left you get to the other side.
that's what I've meant, that jumping etc will bring you back to where you started...
anyway, i can't find in your links a proof that jumping will not bring you back to the point you left the ground (neither something similar)...
another way to look at it is if you are standing on a moving platform and you jump you don't suddenly stop you continue moving at that speed until air resistance or another force slows you down.
You should imagine how this happens when viewed by a stationary observer. If somebody jumps toward the centre, it's obvious they'll travel in a perfect straight line at a perfectly constant speed.
But you have to remember they're also launched sideways with the addition of the instantaneous velocity from the moving wall. So if they aim for the centre, they'll definitely miss it, just because of their sideways velocity which came from being in contact with the wall. To get to the centre they have to aim slightly backward to exactly cancel out the motion of the wall/wheel.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
