| Thread Closed |
Thickness or Ga. of Stainless steel water tank? |
Share Thread | Thread Tools |
| Nov24-09, 12:11 PM | #1 |
How do you calculate the thickness or guage of a given metal (304 Stainless Steel for example) for a 36" dia. round, vertical cylinder water holding tank? If filled say the tank would be 25-30 feet tall. No physical pressure (pumps or vacuum) on this vessel (vented to atmosphere). Flat bottom, not a bulkhead style base. Not sure if water temp matters but for the sake of measurements if needed. Let say an air temp of 80 deg. F. and a water temp of 130 deg. F. also not sure if it matters but elevation at roughly 1000ft. above sea level.
| Nov29-09, 11:01 AM | #2 |
one possibility is to detremine the inner and outer dia s
and its for sure the pressure changes significantly wrt temperatures and head for the described situation it may nt be of great concern |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thickness or Ga. of Stainless steel water tank?
| Determine the thickness of steel plate (based on S275 steel) | General Engineering | 10 | ||
| Stainless Steel in Sea Water | Introductory Physics Homework | 8 | ||
| Thickness of T304 stainless steel | Mechanical Engineering | 5 | ||
| Which stainless steel? | Materials & Chemical Engineering | 3 | ||
| Stainless Steel | Chemistry | 10 | ||
