Thread Closed
Find acceleration of a Block within a simply pulley system.
Share Thread Thread Tools
Dec11-09, 02:57 AM   #1
The figure shows two blocks suspended by a cord over a pulley. The mass of black B is twice the mass of black A, [tex]m_b = 2m_a = 2m[/tex]. The mass of the pulley is equal to the mass of black A, [tex]m_p = m_a = m[/tex], the radius of the pulley is [tex]R[/tex]. The blocks are let free to move and the cord moves on the pulley without slipping or stretching. There is no friction in the pulley axle, and the cords are massless. The rotational inertia of the pulley is [tex]\frac{m_pR^2}{2}[/tex] about a perpendicular axis through the center. Find the magnitude of acceleration of the block B. Express your results in the simplest possible form in terms of any or all the following: m, g, R, and universal physical or mathematical constants.
2. Relevant equations
[tex]F_G = m * g[/tex] (force of gravity equals mass times gravitational acceleration)
[tex]\tau_net = I * \alpha[/tex] (torque equals moment of inertia times angular acceleration)
3. The attempt at a solution
[tex]\tau_{net} = I * \alpha = \frac{m * R^2}{2} * \alpha = \frac{m * R^3}{2} * a[/tex]
furthermore,
[tex]\tau_{net} = F_{G on B} * R + F_{G on A} * R = 2 * m * g * R - m * g * R = m * g * R[/tex]
so,
[tex]m * g * R = \frac{m * R^3}{2} * a[/tex]
which leads to the answer:
[tex]a = \frac{2 * g}{R^2} m/s^2[/tex]
Is this correct? Is there an easier way?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec11-09, 11:33 AM   #2
bump... picture of problem lol
Dec11-09, 01:09 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by cocoon View Post
oops, slight error in your equation there [tex]a = \alpha R, [/tex] so [tex] \tau = MRa/2 [/tex]
furthermore,
no, that's not right, you've assumed the respective tension forces are equal to the respective weights, but the system is accelerating, so the tensions cannot equal the weights
No, this is incorrect, you need to write 3 equations with 3 unknowns, T_A, T_B, and a, so draw Free Body diagrams (FBD's ) of each block and the pulley to solve for them...... separte FBD's and application of Newton's laws to each are essential in these type problems. Trying to take shortcuts often results in incorerct methods and solutions.
Dec11-09, 03:37 PM   #4
this accn.. u solved is for t he pulley not for the block B
so use the principle of energy conversion to solve the problem then it will give the acceleration for block B..
Thread Closed
Thread Tools
Similar Threads for: Find acceleration of a Block within a simply pulley system.
Thread Forum Replies
Tension and acceleration of a pulley sytem attached to a block Introductory Physics Homework 3
pulley and block system tension & acceleration Introductory Physics Homework 1
block on an incline connected to a mass...cord...pulley...26˚. acceleration? Introductory Physics Homework 3
Acceleration in a Pulley System Introductory Physics Homework 5
Pulley system acceleration Introductory Physics Homework 1
