Output impedance of an op-amp is very small
In summary, the input impedance of an op-amp is important in order to prevent loading of the source and maintain accuracy for delicate sensors. On the other hand, the low output impedance allows for the op-amp to supply current to poorly-behaved devices without affecting the source. This is why op-amps are sometimes referred to as "buffers." Additionally, in feedback configurations, high input impedance is necessary for idealization and low output impedance is desirable for efficiency.
denian
641
i know that output impedance of an op-amp is very small compared to its input impedance. is there any purpose of having a high input impedance and small output impedance?
Yes, there's a purpose. You want the op-amp to avoid pulling much current from whatever is supplying its input. This is called loading the source and is usually a bad thing. If you were trying to amplify the signal from a delicate sensor, for example, the sensor might not be able to supply much current at all without disturbing its accuracy. You therefore don't want the op-amp to load the sensor much at all.
On the other hand, whatever is receiving the sensor signal after the op-amp might be a very poorly-behaved device. Maybe it's an analog-to-digital converter or a meter that pulls tons of current. You wouldn't want to connect this current-hungry device directly to the sensor, but you could connect it to the op-amp. The op-amp has a very low output impedance and doesn't mind sourcing a lot of current.
This is why op-amps wired up in the voltage-follower configuration are sometimes called "buffers." They essentially buffer or protect their input from whatever's on their output.
- Warren
Moved to EE..
- Warren
To elaborate on the utility of high input impedence, consider the theory behind the ideal opamp in a feedback configuration. It is essential to the idealization that negligible current flows into the input, thereby allowing you to approximate the feedback mesh and develop those convenient equations for gain.
Low output impedance is desirable for basically the same reason that low internal resistance in a battery is desirable (and what chroot said).
thank you for all the explanations. it helps.
What is the output impedance of an op-amp?
The output impedance of an op-amp refers to the resistance that is present at its output terminal. It is a measure of how much the output voltage changes when a load is connected to the output.
Why is the output impedance of an op-amp important?
The output impedance of an op-amp is important because it affects the accuracy and stability of the output voltage. A low output impedance means that the op-amp is less affected by the connected load and can maintain a consistent output voltage.
How is the output impedance of an op-amp determined?
The output impedance of an op-amp is determined by the internal circuitry of the op-amp and its design. Typically, op-amps are designed to have a very small output impedance in order to minimize the effect of the load on the output voltage.
What are the benefits of a small output impedance in an op-amp?
A small output impedance in an op-amp allows for better performance and stability in the output voltage. It also allows for the op-amp to drive larger loads without significant changes in the output voltage. This is especially important in applications where a precise and consistent output is required.
Can the output impedance of an op-amp be changed?
The output impedance of an op-amp is a characteristic of its design and cannot be changed. However, it can be compensated for by using external components such as resistors or capacitors in the circuit. These components can help reduce the effect of the op-amp's output impedance on the output voltage.
  • Electrical Engineering
