What is the Ratio of Speeds After a Noncentral Elastic Collision?
In a noncentral elastic collision between two spheres, one with a mass of 0.3 kg and the other 0.35 kg, the first sphere transfers 79% of its kinetic energy. The initial velocity of the first sphere (u1) is unknown, while the second sphere (u2) starts at rest. The calculations show that the ratio of their speeds after the collision is v1 : v2 = 1 : 3.224. The discussion emphasizes the importance of incorporating kinetic energy relationships into the calculations for accuracy. Ultimately, the correct application of kinetic formulas leads to a valid solution.
EPhoenix
First sphere m=0.3 kg collide noncentraly and elasticaly with other sphere of m= 0.35 kg and transfer 79% of first sphere kinetic energy during that collision... u1 is not defined, u2 = 0 m/s
Ratio between speed after collision v1 : v2 = ??
m1u1 + m2u2 = m1v1 + m2v2
Tryied to make Ek = Ek1 + Ek2
m1u1 = m1v1 + m2v2
m2v2 = 0.79 m1u1
v2 = 0.677 u1
m1v1 = 0.21 m1u1
v1= 0.21 u1
so ratio would be
v1 : v2 = 0.21u1 : 0.677u1
so in conclusion
v1 : v2 = 1 : 3.224
But I don't know if it's false or right...
hmmm , your solution doesn't seem logical enough to me .. for example why didnt you use the fact that k=0.mv^2 (or p^2/2m) ??notice what is the relationship between the kinetic energy and the velocity(or momentum) .. how would that change your calculations? .. please try again ..
Yeah... I got right solution after applying it with kinetic formula...
Thx nevertheless :)
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
