What are some helpful tips for solving AP & GP questions?
  • Thread starter Thread starter Follz20
    Ap
To solve the arithmetic progression (AP) problem, use the equations a + d = 4.5 and a + 9d = -7.5 to find the first term (a) and common difference (d), then apply the sum formula for the first ten terms. For the geometric series, identify the common ratio to calculate the sum of the first ten terms and the sum to infinity using the appropriate formulas. The ball's total distance can be determined by creating a summation series that accounts for the height of each bounce. These methods provide a structured approach to tackling AP and GP questions effectively.
Follz20
Hi all. Any help on these annoying questions will be much appreciated!
1) The second term of an AP is 4.5 and the tenth term is -7.5. Find the sum of the first ten terms.
2) For the series √2 + 1 + 1/√2 + ...
a) Find the sum to ten terms of the series
b) what is the difference between the sum to ten terms and the sum to infinity?
3) A ball is dropped from a height of ten metres. It continually bounces back up to a height equal to four-fifths of its previous height. Find the total distance traveled by the ball.
I am quite bad at this so any help or tips from anyone will be gladly accepted! Cheers! :blushing:
Mathematics news on Phys.org
1) We are given that a+d=4.5 and a+9d=-7.5 where a is the first term and d is the difference between each term. Solve these 2 equations simultaneously and then plug your results into your sum of an arithmetic formula.
2)
a)What is the ratio between each term? This should be enough to simply plug into your geometric summation formula!
b)The same deal, just use your sum to infinite of a geometric series formula and then it's obvious from there.
3)Can you create a summation series to describe the distances the ball is travelling?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
