Gas pressure in variable diameter pipe
In a variable diameter pipe system, the section of 4" pipe before it narrows to 3" will indeed experience a vacuum relative to the narrower section, as explained by Bernoulli's principle and the venturi effect. The discussion revolves around optimizing a compound boost setup for a 5.3L engine, where a roots-style blower is complemented by a turbocharger to enhance high-end power. The challenge lies in managing boost pressure, as it can become uncontrolled in compound systems. A proposed solution involves creating a sequential boost system where a vacuum in front of the turbo activates a bypass valve on the blower. The key focus is determining the appropriate dimensions for the turbo inlet to generate the necessary vacuum to trigger the bypass valve effectively.
anasasis
This may be an elementary question, but I am still in the elementary stages of physics. My question is this: if you have a 4" fan at the end of a 4" pipe which is sucking air through the pipe, and the pipe narrows to 3" about 24" from the fan, does the 24" section of 4" pipe experience a vacuum relative to the 3" section of pipe? Assume the volume of air being pulled by the fan is either constant or increasing.
Yes. That's bernoulli's principle and the venturi effect. Have a look at the wiki for those subjects and then we can take it deeper if you like.
Okay, well a little background on what I'm trying to do. I have a project vehicle that I would like to run compound boost on. It is a 5.3L engine currently with a roots-style, positive displacement blower on it. I put the blower on, and it is plenty powerful on the low end. Torque is immediately available, and that's what this type of blower is made for...but it lacks severly on the high end powerband. My solution is to put a turbocharger in front of it to help with the high end.
The problem people run into with compound setups is uncontrolled boost because the pressures multiply once they reach the blower. I would like to fix this by making the compound boost sequential instead of simultaneous, whereas vacuum in front of the turbo compressor activates a bypass valve on the blower to allow it to flow pressure freely while the turbo is making boost.
Now, all I need to do is figure out what dimensions to use when I fabricate the inlet on the turbo so that it will create the vacuum necessary to trigger the blower bypass valve. It takes 15 inHg to open the valve all the way. My idea is that by narrowing the inlet pipe some distance from the opening of the compressor in the turbo, that certain distance will experience a vacuum relative to the rest of the inlet pipe. I've got the concept, but where is a good place to start?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
