Entropy, free energy and chemical potential of mixtures
This discussion focuses on the thermodynamic properties of a mixture of ideal gases, specifically addressing entropy, internal energy, Helmholtz free energy, and Gibbs free energy. The participants derive expressions for these properties based on the ideal gas law and discuss the implications of removing diathermal separators on entropy changes. Additionally, the chemical potential for each component is calculated, demonstrating the relationship between chemical potential, concentration, and temperature.
  • Understanding of ideal gas laws and thermodynamic properties
  • Familiarity with entropy calculations for ideal gases
  • Knowledge of Helmholtz and Gibbs free energy definitions
  • Basic principles of chemical potential in thermodynamics
  • Study the derivation of entropy changes in thermodynamic systems
  • Learn about the implications of diathermal separators in gas mixtures
  • Explore the concept of chemical potential in detail, particularly in mixtures
  • Investigate the relationship between concentration and chemical potential in ideal gases
Students and professionals in thermodynamics, particularly those studying or working with gas mixtures, chemical engineering, and physical chemistry.
Derivator
Hi,
Consider a mixture of different gases with [tex]N_i[/tex] molecules each (i=1...k denotes the species).
For ideal gases the following relation yields:
[tex]S(T,V,N_1,...N_k)=\sum_{i=1}^k S_i(T,V,N_i)[/tex]
a)Give explicit expressions for the entropy, the internal energy, Helmholtz free energy and Gibbs free energy
b) What is the change in entropy, if the k components are initially separated by moveable and diathermal seperators which get removed.
c) Calculate for this mixture the chemical potential [tex]\mu_i[/tex] for each component and show that the following relation holds:
[tex]\mu_i(p,T,N_1,...,N_k)=\mu_{i,0}(p,T) + kT\ln(c_i).[/tex]
Where [tex]c_i := N_i/N[/tex] (with [tex]N = \sum_i N_i[/tex]) is the concentration of the i-th component and [tex]\mu_{i,0}(p,T)[/tex] the chemical potential of the i-th component in unmixed state.
I have no idea at all, how to solve this exercise. Here is my attempt:
a)
Entropy:
I know from http://books.google.com/books?id=12... thermodynamics&pg=PA42#v=onepage&q=&f=false" that the entropy of an ideal gas is given by
[tex]S_i(T,V,N_i) = S_0 + N_i k \ln\left(\left(\frac{T}{T_0}\right)^{3/2}\frac{V}{V_0}\right)[/tex]
So the entropy of the mixture (which we look for) may be given by the sum over this expression. Correct?
Internal energy:
I know that the internal energy is an extensive property, so
[tex]U = \sum_i U_i[/tex] with [tex]U_i = \frac{3}{2}\cdot N_i \cdot k \cdot T[/tex]
But I think, i should derive the internal energy of the mixture from the given equation [tex]S(T,V,N_1,...N_k)=\sum_{i=1}^k S_i(T,V,N_i)[/tex].
Helmholtz free energy:
Helmholtz free energy is given by
[tex]A = U - T\cdot S[/tex]
But how should I give an explicit expression for the mixture.
Gibbs free energy:
It is given by:
[text]G = H - T\cdot S[/tex]
Same problem as for the Helmholtz free energy, I don't know how to give an explicit expression for the mixture.b)
I think, due to the diathermal seperators, I can assume, that each component has the same temperature. But I don't know how to take into account that the seperators are moveable.
To be honest, I have no clue at all, how to solve this part...c)
According to the definition in our lecture, the chemical potential is given by:
[tex]\mu_i = \left(\frac{\partial U}{\partial N_m}\right)_{(S,V,N_1,...,N_k)}[/tex]
where U is the internal energy and N_m the number of particles of species m.
So i probably should derivate
with respect to N_i, to get [tex]\mu_i[/tex]
However, I see to chance how to show with this derivation, that the following relation holds:
(Sorry for my english, it's not my native language)
derivator
*push*
ok folks, let's look at b), please:
Entropy will change, because the available volume for one species will change. So I can take my formula for entropy
[tex] S_i(T,V,N_i) = S_0 + N_i k \ln\left(\left(\frac{T}{T_0}\right)^{3/2}\frac{V}{V_0}\right)[/tex]
and calculate
[tex] \Delta S = \sum_i{S_i(T,V,N_i)} -\left(S_0 + N_i k \ln\left(\left(\frac{T}{T_0}\right)^{3/2}\frac{V_i}{V_0}\right)\right)[/tex]
and simplify it.
But I didn't took notice of those movable separators. Do I have to take notice of them?
--derivator
