| Thread Closed |
Angular Momentum and Principal Axes of Inertia |
Share Thread | Thread Tools |
| Mar29-10, 04:57 PM | #1 |
Hi
Iīm self-studying Alonso and Finnīs Mechanics and I have a question about this subject. Let a body rotate about an arbitrary axis P having angular momentum [tex]\vec L [/tex]. Consider a referential with three perpendicular axes, [tex] X_{0} , Y_{0} , Z_{0} [/tex] , which are also principal axes of inertia. The book says we can write [tex] \vec L [/tex] as [tex] \vec L = \vec u_{x} I_1 \omega_{x0} + \vec u_{y} I_2 \omega_{y0} + \vec u_{z} I_3 \omega_{z0} [/tex] Does anybody how to derive this formula? The book usually explains things, but perhaps this is supost to be obvious. By the way, I already know how to derive [tex] \vec L = I \vec \omega [/tex] for a body rotating about a principal axis of inertia but I donīt know how to derive this one. Thank you
| Mar29-10, 06:00 PM | #2 |
Recognitions:
Generally, if a rigid body is rotating about an arbitrary axis, the angular momentum need not point in the same direction as the rotation axis, as it does when [itex]\vec L = I \vec \omega [/itex] (for rotation about a principal axis).
The relation between [itex]\vec L[/itex] and [itex]\omega[/itex] is still linear, and I is generally a tensor quantity (the inertia tensor). An object always has three principal axes and in that coordinate system the inertia tensor is diagonal. This leads directly to: [tex] \vec L = \vec u_{x} I_1 \omega_{x0} + \vec u_{y} I_2 \omega_{y0} + \vec u_{z} I_3 \omega_{z0} [/tex] It's really the only thing it can be if you know [itex]\vec L = I \vec \omega [/itex] holds for principal axes, there are three principal axes and the correspondence between [itex]\vec w[/itex] and [itex]\L[/itex] is linear. |
| Mar29-10, 06:51 PM | #3 |
Hello Galileo,
Thanks for the answer. Unfortunately, I couldnīt follow it because I donīt know what a tensor is. Iīm still a high school student. I guess Iīll just have to use it without knowing how to derive it. which is something I really hate. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Angular Momentum and Principal Axes of Inertia
| Physics Rotating Disk, Moment of Inertia, Angular Momentum, Angular Velocity | Introductory Physics Homework | 12 | ||
| principal axes/inertia tensor | Advanced Physics Homework | 2 | ||
| What are the principal axes? | Classical Physics | 12 | ||
| Fluid Flow: Principal Rates of Deformation/Principal Axes | Mechanical Engineering | 1 | ||
