| Thread Closed |
Heat transfer (convection & radiation) |
Share Thread |
| Apr6-10, 10:12 PM | #1 |
Two large thin aluminum plates, the first polished (emittance = 0.05 and the second painted black, are placed horizontally outdoors, where they are cooled by air at 283K. The heat transfer coefficient is 5 W/m^2-K on both the top and bottom. The top is irradiated with 750 W/m^2 and it radiates to the sky at 170K. The earth below the plate is black at 283K. Find the equilibrium temperature of each plate. 2. Relevant equations Q_conv = hA(Ts-Tenv) Q_rad = e*sigma(Ts^4-Tsurr^) 3. The attempt at a solution First I started by thinking about what equilibrium temperature is and I think its the change in heat transfer in the plate is zero. Second, I drew a figure and I labeled the directions, we have the 750 W/m^2 going into the plate, radiation coming out, and convection going out from both the top and bottom faces. I attempted it with the black plate and got an answer fairly close to the answer. The answer is 303.23K and I got about 310K. However, using the same method I got an answer much higher with the polished plate which leads me to believe my approach is wrong. Thank you for any help. |
| Apr7-10, 06:13 AM | #2 |
No radiation going towards the ground?
| Apr7-10, 12:37 PM | #3 |
But, my problem with the polish plate still exists where I am getting a higher temperature than the black plate. The correct answer should be 285.06K. I added the emittance to the radiation going towards the sky and also tried going towards the earth. My answer is 326K and 359K respectively. |
| Apr7-10, 12:49 PM | #4 |
Think of what happens when you shine 750 W m-2 at a mirror. It is all going to be absorbed, or do you need to adjust that value to take reflectivity into account?
| Apr7-10, 01:04 PM | #5 |
I figured it out, I forgot to included emittance for the amount of heat it radiates out. Thanks again.
| Apr7-10, 01:21 PM | #6 |
I missed that detail too until you reported that the first answer was wrong!
| Thread Closed |
Similar discussions for: Heat transfer (convection & radiation)
| Convection heat transfer, Fluent vs Calculations | Mechanical Engineering | 13 | ||
| Heat transfer forced convection problem | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Heat Transfer Problem Conduction and Convection | Engineering, Comp Sci, & Technology Homework | 12 | ||
| Heat Transfer Convection Resistance Issue | Mechanical Engineering | 1 | ||
| Subatomic mechanism of heat transfer by convection? | Classical Physics | 3 | ||
