Thread Closed
MATLAB for uniform random variables
Share Thread
May4-10, 03:18 PM   #1
Given 2 independent uniform random variables X,Y = U [0,1], consider the random variables Z = g (X,Y) for g = (x,y) = sqrt (-2ln(x) . cos(2piy). Since finding the distribution of g(X,Y) analytically is quite tough, I need to generate MATLAB program for
1 - 10,000 uniformly distributed random samples for X and Y
2 - For each sample of X and Y, compute Z= g(X,Y)
3 - Draw a histogram over the resulting samples in Z
4 - Estimate the moments mZ for n = 1,2....6.
3. The attempt at a solution
I tried for the first solution and I'm hopelessly stuck. MATLAB gives me an error saying "Attempted to access (0,1); index must be a positive integer or logical."
I don't understand where I'm going wrong.
Please help!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
May4-10, 03:38 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Please post exactly what Matlab command you have typed which produces that error.
May4-10, 03:48 PM   #3
I tried to put the formula into MATLAB and this was my program
x= 0;
>> y= 1;
>> rand (1, 1000);
>> g= sqrt((-2*log(x)) * cos((2*pi*y)));
>> plot(g)
Actually, for this, I get a blank plot.
Please point out the mistake.
May4-10, 05:03 PM   #4
Mentor
Your error message came from an attempt to access the (0, 1) element of a an array.
Before starting to code, you should take a look at the Matlab documentation to learn how to use such functions as rand, log, and plot. In the code you show, x is 0, and your fourth line is attempting to take the log of 0
Getting started with MATLAB
User documentation
I can't really give you much help, since your code is a VERY LONG way from doing what you need it to do.
May4-10, 06:04 PM   #5
Thanks for your comments but I need to point out thats the question in the first place. So there is no chance I can take a different value.
How do you suggest I define the vectors then? One of the vector (x) is multiplied with the log and the second vector (y) is multiplied with cos (2pi). And the question says X (note the upper case) = U (0,1)
May4-10, 06:28 PM   #6
Mentor
Quote by electroissues View Post
In your first post you said that X is uniformly distributed in [0, 1]. Below, you have changed that to say that X is uniformly distributed in (0, 1). The first interval includes 0 (and 1, but that's not a problem); the second interval doesn't include 0.
NO, it's NOT "multiplied with log" and NO, it's NOT "multiplied with cos (2pi)." These are functions, not numbers that you multiply by.
You can define your vectors X and Y as one-dimensional arrays with 10,000 elements or as two-dimensional arrays with 100 rows and 100 columns. It doesn't make any difference, but you need to learn how to work with vectors and/or arrays in MATLAB. The first link I gave in my earlier post can show you how to work with arrays.
May5-10, 10:08 AM   #7
Thanks, Mark. I read the documentation.
In my first post, the question has U= [0,1] with 10,000 random variables.
Can you please tell me how I shud use this in the rand function? Also, please help with the substitution for x and y if I define the rand as "rand [1, 10000]"
Thanks again.
May5-10, 12:50 PM   #8
Mentor
Yes, I'm aware of what you had in your first post. My comment was that in post #5 you said U(0, 1), so which is it?
Here's from the documentation for rand: "r = rand(n) returns an n-by-n matrix containing pseudorandom values drawn from the standard uniform distribution on the open interval (0,1). rand(m,n) or rand([m,n]) returns an m-by-n matrix."
You can do this to create a 100 x 100 array of random numbers in the open interval (0, 1):
X = rand(100)
Or you can do this to create a vector of length 10000 of numbers from the same interval:
X = rand(1, 10000)
Whatever you do to create your X array, do the same to create the Y array.
Thread Closed
Tags
matlab, random variables, uniform distribution
Similar discussions for: MATLAB for uniform random variables
Thread Forum Replies
Sum of two continuous uniform random variables. Calculus & Beyond Homework 18
Proof of the statement: sum of two random variables is also a random variable Set Theory, Logic, Probability, Statistics 8
Expectation and variance of a random number of random variables Calculus & Beyond Homework 3
PDF of function of 3 continuous, uniform random variables? Set Theory, Logic, Probability, Statistics 3
joint density of uniform random variables Calculus & Beyond Homework 0
