Center of Gravity, Non-Uniform Bar
The discussion focuses on calculating the center of gravity for a non-uniform bar with a length of 4.3 meters, subjected to a force of 10N. The angle z is given as 56.2 degrees, and the user employs trigonometry to analyze the forces acting on the bar. Key insights include the necessity for the total vertical force to equal 10N for equilibrium and the conclusion that horizontal forces can be utilized to determine the distribution of forces at the poles supporting the bar.
  • Understanding of static equilibrium in physics
  • Basic trigonometry for force calculations
  • Knowledge of center of gravity concepts
  • Familiarity with forces acting on structures
  • Study static equilibrium principles in physics
  • Learn advanced trigonometric applications in force analysis
  • Explore methods for calculating center of gravity in non-uniform objects
  • Investigate the effects of different force distributions on structural stability
Students in physics, engineering professionals, and anyone involved in structural analysis or mechanics will benefit from this discussion.
JasonRox
This is a question I need to do, I'm just going to put an example on what the question is like. In case a teacher of mine comes on here, I know I'm not "cheating".
Here is the image:
l\
lz.\.../l
l...\..../xl
l...\______/...l
l...l____q_l...l
l.....l
*Ignore dots.
z=56.2 degrees
x=90-56.2 degrees
q=center of gravity
lenght of bar is 4.3m
Find the distance from the right side of the bar, where the center of gravity is located.
This is all the information they give you. Simliar style, but not the same.
I started with using the Force of the bar as 10N. Easy number.
Then I find the force on the ropes, using trigonometry. I also find the horizontal forces as well.
The part I'm stuck on is how much force is actually used by each pole to keep the bar up.
The total vertical force must equal 10N, or else it won't stay up, or go up.
Do I use the horizontal forces to determine them?
I was thinking of using the difference between the two horizontal forces, and use the ratio to determine how far it is from the center.
Is this correct?
Yes, you can use the horozontal forces to solve the problem.
The clue is that, since the bar is in equilibrium, the total horizontal force = zero.
Hence, the horoizontal components of the ropes are equal and in opposite directions.
Work it out from here
I found it now.
I think I did anyways.
26K
  • · Replies 18 ·
