| Thread Closed |
Conservation of Angular Momentum: angular speed |
Share Thread |
| Jun14-10, 09:15 PM | #1 |
A student sits on a freely rotating stool holding 2 3.00kg dumbbells. When the students arms are extended horizontally the dumbbells are 1.00m from the axis of rotation and the student rotates with an angular speed of 0.750 rad/sec. The moment of inertia of the student and the stool is 3.00 kgm2 and it is assumed to be constant. The student pulls the dumbbells in to a position 0.300m from the rotation axis. What is the new angular speed? 2. Relevant equations I was going to try Ii[tex]\omega[/tex]i=If[tex]\omega[/tex]f but the problem with this is that the problem says I is constant at 3.00 kgm2. I assume that I need to factor in the radius somehow but I'm not sure how to do it. 3. The attempt at a solution |
| Jun14-10, 09:29 PM | #2 |
Recognitions:
When the dumbells are at 1m, what is the moment of inertia of them?
Add that to the inertia of the stool and you have the initial moment of inertia. initial angular momentum = Iinitialωinitial. When the dumbells are at 0.3m, what is the moment of inertia then? (Add this to get inertia of the stool to get the final moment of inertia) |
| Jun14-10, 10:00 PM | #3 |
So can I model the dumbbells as a rod and use 1/12 ML2 as the moment of inertia or do I have to integrate [tex]\int[/tex][tex]\rho[/tex]dV? I am facing problems with both ways, I don't know what the volume would be if I integrate, and it seems like modeling as a rod would not be correct.
| Jun14-10, 10:21 PM | #4 |
Recognitions:
| Thread Closed |
Similar discussions for: Conservation of Angular Momentum: angular speed
| Finding angular velocity using conservation of angular momentum | Introductory Physics Homework | 2 | ||
| Conservation of angular momentum | Advanced Physics Homework | 3 | ||
| Conservation of Angular Momentum | Introductory Physics Homework | 1 | ||
| angular momentum conservation help | Introductory Physics Homework | 1 | ||
| Please Help with Angular Momentum/Angular Speed | Introductory Physics Homework | 3 | ||
