Definition of unit of electric current
The ampere is defined as the constant current that, when maintained in two infinitely long, parallel conductors with negligible circular cross-sections placed one meter apart in a vacuum, generates a force of 2 × 10^(-7) Newton per meter of length between them. The mention of "orange colored text" refers to the consideration of the wires being infinitely thin, which is a crucial aspect of this definition.
Quantumkid
The ampere is that constant current which , if maintained in two straight parallel
conductors of infinite length, of negligible
circular cross-section, and placed 1 metre apart in vacuum, would produce between
these conductors a force equal to 2 × 10 ^{–7} Newton per metre of length.
What is meant by orange colored text??
Chemistry news on Phys.org
Yes - and your question is ?
It means that one considers the limit that the wires are infinitely thin.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
