A Charged Particle in a Uniform Electric Field
In summary, the conversation discusses the motion of a charged particle in a simple uniform electric field. The general consensus is that the particle would follow Newton's second law of motion with a constant acceleration, but the generation of electromagnetic waves would result in a decrease in the acceleration. The equation for the energy radiated by the particle is also mentioned, and it is found that the radiation loss is negligible unless the energy gain is on the order of 2e14 MeV/m. The conversation also touches on a potential solution to the proposed differential equation, but it is ultimately deemed a dead end due to the difficulty in extracting v as v=f(t). A better starting point for solving the problem is suggested, but it is noted that the equations of motion currently
ThorX89
Hi.
I'm curious, how would a charged particle, let's say an electron, move in a simple uniform electric field?
My first guess would be that it would follow Newton's second law of motion and move with a constant acceleration:
[tex]$ \dot{x}=\frac{Eq}{m} $[/tex]
where E is the fields intensity, q the charge, and m it's mass.
However, an accelerated charge should generate electromagnetic waves.
These have energy and so the motion wouldn't accelerate as fast.
I found that the energy radiated by these should be equal to:
(Larmor formula) for norelativistic speeds.
So I would assume that the work done by the electric field on the charge in a fraction of time:
[tex]$ P_{el} = q\cdot E \cdot \dot{x} $[/tex]
would be used to a) increase the kinetic energy of the particle b) used for the radiation energy:
[tex]\[P_{el}=\frac{d}{dt}(\frac{1}{2}m\dot{x}^2) + P_{rad}\][/tex]
That leads to the differential equation:
[tex]$ A \cdot \dot{x} = m \cdot \dot{x} \cdot \ddot{x} + B \cdot \ddot{x}^2 $[/tex]
where
[tex]$ A=Eq ; B=\frac{{q^2}}{{6\cdot\pi\eps_0\ c^3}} $[/tex]
(just to make it look simpler).
I have now idea how to solve this.
Do you think my reasoning is right? If so, can anybody find a solution?
How is the motion of a charged particle in a uniform electric field truly described?
I'd think this is quite a simple question, but I couldn't find any simple answer to it on the Internet.
I appreciate any help.
It's negligible. The radiated power for linear acceleration, for relativistic effects accounted for, is
[tex] P = \frac{2}{3}\frac{e^2}{m^2c^3}\left( \frac{dp}{dt} \right)^2 [/tex]
Now, instead of substituting -qE as our force here, we will note that the rate of change in the momentum is also equal to the change in energy of the particle per unit distance. This obvious from the fact that work is the integral of F*dx. Thus,
[tex] P = \frac{2}{3}\frac{e^2}{m^2c^3} \left( \frac{dE}{dx} \right)^2 [/tex]
This allows us to express the power radiated as a function of the external forces that are applied as opposed to the properties of the particle. Now, the ratio of the power radiated to the power supplied by the external source is
[tex] \frac{P}{(dE/dt)} = \frac{2}{3}\frac{e^2}{m^2c^3} \frac{1}{v} \frac{dE}{dx} [/tex]
Where we have made use of the chain rule. In the limit of a relativistic speed,
[tex] \lim_{v\rightarrow c} \frac{P}{(dE/dt)} = \frac{2}{3}\frac{(e^2/mc^2)}{mc^2}\frac{dE}{dx} [/tex]
Thus, the radiation loss is negligible unless the gain in energy is of the order of mc^2 over a distance of e^2/mc^2. In other words, a change in energy on the order of 2e14 MeV/m. Jackson states that typical gains are around 50 MeV/m or less. Obviously, we need an electric field of an inconceivable size.
So, in short, the answer to your question is that we simply use
[tex] ma = -eE[/tex]
because we do not work with electric fields strong enough to bleed enough energy off of the electron as it is linearly accelerated to make a difference.
I attempted a solution to the differential equation I proposed
and I got ended up with
this
http://integrals.wolfram.com/index.jsp?expr=2/(-x-Sqrt[x^2%2B4B%2Fx*A]%29&random=false
or
http://integrals.wolfram.com/index.jsp?expr=2/(-x+Sqrt[x^2%2B4B%2Fx*A]%29&random=false
for t, where x actually stands for v=dx/dt.
Ie. no hope of extracting v as v=f(t) so basically a dead end.
So this this is a really nice solution you gave me - when you can't deal with something, just show it's not worth dealing with. :-)
Thanks a lot.
this
or
Thanks a lot.
Here's a better way you can get to in by two different paths. The differential equation that we have, I have changed to a positron so that all the distances and accelerations should be positive with respect to E, is
[tex] m\dot{x}\ddot{x} = eE\dot{x}-\frac{2e^2}{3c^3}\ddot{x}^2[/tex]
Solving for the acceleration we get
[tex]\ddot{x} = \frac{3mc^3\dot{x}}{4e^2} \left[ -1+ m\dot{x} \sqrt{ 1 + \frac{8e^3E}{3m^2c^3\dot{x}}} \right][/tex]
Now we take the Taylor's expansion of the square root and get
[tex]\ddot{x} \approx \frac{eE}{m} - \frac{2e^4E^2}{3m^3c^3\dot{x}} [/tex]
In other words,
[tex] m\dot{x}\ddot{x} \approx eE\dot{x} - \frac{2e^4E^2}{3m^2c^3} [/tex]
But this is the same thing as if we did a first order approximation and used eE as the force in the radiated power formula and placed it into the original differential equation. Either way, we come to the same first order approximation. The kinetic energy is thus
[tex] \frac{1}{2}m\dot{x}^2 \approx eEx - \frac{2e^4E^2}{3m^2c^3} t [/tex]
So here is a better starting point to work with. As for solving this, hmmm...
EDIT: Now that I think about it, I don't think the above will work. Because of the small amount of power that is radiated, we would have to use equations that follow special relativity, but currently the above equations of motion allow for unbounded velocities. Oh well, we have at least proven what the first order approximation is and that is derived from a formula that works for relativistic particles. So this approximation should be valid to be substituted into a set of equations of motion that do follow special relativity.
I can say that your reasoning is correct. The motion of a charged particle in a uniform electric field is indeed described by Newton's second law of motion, as you have stated. However, as you have also pointed out, the accelerated motion of the charged particle will also generate electromagnetic waves, which will in turn affect the motion of the particle. This is known as radiation damping.
To accurately describe the motion of a charged particle in a uniform electric field, we need to consider both the effects of the electric field and the radiation damping. This can be done by solving the differential equation you have derived, which takes into account both the work done by the electric field and the energy lost due to radiation damping.
Solving this differential equation can be quite complex, but there are numerical methods and simulations that can be used to accurately describe the motion of the charged particle. Additionally, there are also simplified models that can be used for specific cases, such as the non-relativistic case you have mentioned.
Overall, the motion of a charged particle in a uniform electric field is a complex phenomenon that requires a thorough understanding of both classical mechanics and electromagnetism. I hope this helps answer your question and encourages you to further explore this topic.
1. What is a charged particle in a uniform electric field?
A charged particle in a uniform electric field is a particle that has a positive or negative charge and is placed in an electric field that has a constant strength and direction throughout its entire region.
2. How does a charged particle behave in a uniform electric field?
In a uniform electric field, a charged particle will experience a force in the direction of the electric field, causing it to accelerate or decelerate depending on the direction of the electric field and the charge of the particle.
3. What is the formula for calculating the force on a charged particle in a uniform electric field?
The formula is F = qE, where F is the force in Newtons, q is the charge of the particle in Coulombs, and E is the strength of the electric field in Newtons per Coulomb.
4. How does the velocity of a charged particle change in a uniform electric field?
The velocity of a charged particle in a uniform electric field will change in the direction of the electric field, either increasing or decreasing depending on the charge of the particle and the direction of the field. The magnitude of the velocity will depend on the strength of the electric field and the time the particle is under its influence.
5. What are some real-world applications of a charged particle in a uniform electric field?
A charged particle in a uniform electric field is used in many technological devices, such as cathode ray tubes (CRTs) in televisions and computer monitors, particle accelerators, and mass spectrometers. It is also used in medical imaging techniques such as X-rays and MRI machines.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
