How to Use Maclaurin Expansion to Find e Correct to Four Decimal Places?
To find the value of e using the Maclaurin expansion accurate to four decimal places, it is necessary to include enough terms so that the remainder is less than 0.00005. The discussion emphasizes that simply using the first four terms is insufficient; instead, eight terms are recommended. The size of the omitted terms can be estimated using a remainder term, where the last term's size is determined by the factorial of k+1. By ensuring that this last term is less than 0.00005, the accuracy of the fourth decimal place is maintained. Understanding the remainder term is crucial for achieving the desired precision in the calculation.
pat666
Use the Maclaurin expansion of e^x to find the value of e correct to four decimal places. (This is not the same as simply using the first four terms of the expansion.)
I did the question but i had to look up how many terms to use to be accurate to four decimal places (8) so I am wondering if i should have done it a different way?
see the attachment please.
To make sure you are accurate to 4 decimal places, you have to be sure all the terms you leave out are less than 0.00005, so that leaving it out doesn't change the 4th decimal place even with rounding.
To do that, you need to estimate the size of the terms you leave you, and this is usually done with a remainder term:
e= 1+ 1+ \frac{1}{2!} ... + \frac{1}{k!} + \frac{c}{(k+1)!}
where c is some number between 0 and 1.
So the size of the last term is certainly less than if we take c=1, ie less than 1/(k+1)!. Now you just need to find the value of k so that the last term is less than 0.00005.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
