A property of Chebyshev polynomials
The discussion revolves around a property of Chebyshev polynomials, specifically the composition of these polynomials and their behavior when evaluated at real numbers. Participants explore the implications of this property, potential proofs, and connections to other polynomial sequences, including Lucas sequences.
  • One participant, Tony, seeks a proof for the property that (T_i o T_j)(x) = (T_j o T_i)(x) = T_ij(x) for Chebyshev polynomials when x is any real number.
  • Another participant suggests using complex numbers to find a proof, while Tony proposes using hyperbolic cosine (cosh) as a potential approach.
  • Tony describes a method involving cosh, stating that it allows for the same properties as cosine but for real numbers.
  • There is a mention of a series of polynomials, S_n, that may share similar properties with Chebyshev polynomials, but the connection to cos(nx) or cosh(nx) is unclear.
  • One participant expresses uncertainty about the validity of Chebyshev polynomials outside the interval [-1, 1], emphasizing the importance of the cosine definition in establishing properties and error bounds.
  • Another participant notes that the polynomial (T_j o T_i)(x) - T_ij(x) must be zero for all x in [-1, 1], suggesting implications for the polynomial's behavior.
  • Tony raises questions about the relationships between Chebyshev polynomials and Lucas sequences, indicating a desire to understand their shared properties.
Participants express differing views on the applicability of Chebyshev polynomials outside the interval [-1, 1], with some questioning whether the properties hold for all real numbers. The discussion remains unresolved regarding the generality of the polynomial properties and the connections to Lucas sequences.
There are limitations regarding the assumptions made about the definitions of Chebyshev polynomials and their applicability outside the interval [-1, 1]. The discussion also highlights unresolved mathematical steps in connecting the properties of Chebyshev and S_n polynomials.
Readers interested in polynomial properties, mathematical proofs, and connections between different polynomial sequences, particularly in the context of numerical analysis and number theory, may find this discussion relevant.
T.Rex
Hi,
I fail finding a proof (even in MathWorld, in my Mathematic dictionary or on the Web) for the following property of Chebyshev polynomials:
(T_i o T_j)(x) = (T_j o T_i)(x) = T_ij(x) when x is in ] -inf ; + inf [
Example :
T_2(x) = 2x^2-1
T_3(x) = 4x^3-3x
T_3(T_2(x)) = T_2(T_3(x)) = T_6(x)
When x is in ]-1 ; +1[ , it seems easy to use x=cosA and T_n(cosA) = cos(nA) .
But how to do when x is any real ?
Thanks,
Tony
Mathematics news on Phys.org
You could probably do something clever by letting A be any complex number!
Try doing it with induction.
Hyperbolic Cosinus ?
Huuumm,
I did not find with A being any complex number.
But I thought to use cosh (Hyperbolic Cosinus). It has the same properties than Cosinus about cos(nx). But, with x = cosh(A), we have both A in ]-inf;+inf[ and x in ]-inf;+inf[ . So it's less general than A being complex, but it answers my needs.
The proof:
We define: x=cosh(A) , T_n(x) = T_n(cosh(A)) = cosh(nA) .
So (T_i o T_j)(x) = T_i(cosh(jA)) = cosh(ijA) = (T_j o T_i)(x) = T_[ij](x) .
Now, I have another series of Polynomials that are very close to Chebyshev polynomials:
S_0(x) = 2
S_1(x) = x
S_i(x) = x.S_[i-1](x) - S_[i-2](x) (as with T_n(x) ).
So: S_2(x) = x^2 - 2 , S_3(x) = x^3 - 3x .
It seems to have the same property: S_i o S_j = S_j o S-_i = S_[ij] .
But there is now no way to connect S_n(x) with the properties of cos(nx) or of cosh(nx) ...
I just noticed that, if S_n(x) = Sum{ a_i . x^i } , then T_n(x) = Sum{ 2^(i-1) . a_i . x^i } , where i=0..n .
This series is used in order to prove certain properties of Lucas Sequences, helping to prove the famous LLT (Lucas Lehmer Test): L(0)=4 , L(i) = L(i-1)^2 - 2 , M_q=2^q-1 is prime iff M_q divides L(q-2).
Tony
That's essentially what I was suggesting; the neat thing about cos and cosh is that they're related via cosh x = cos ix. (And also cosh ix = cos x)
Here's another, fairly powerful trick that I wasn't able to remember when I wrote my post:
If f(x) is a polynomial, it either has a finite number of zeroes, or it is the zero polynomial.
You were able to show, using the relationship with cosines, that the polynomial (T_j o T_i)(x) - T_ij(x) = 0 for all x in the interval [-1, 1]. This implies this polynomial must be zero for all x!
So, in other words. T_n(x) = (1/2) * S_n(2x)?
It is not clear to me that if you move outside of the region [-1,1] that you are still dealing with a Chebyshev polynomial. The definition:
[tex]T_k(Cos \Theta ) = Cos k \Theta[/tex]
results in properties used to prove bounds on the resulting errors. If you do not have the cosine then all bets are off on the errors of the resulting function.
The main result of the Chebyshev Polynomial is to obtian the Chebyshev points. These are the points which should be used for ANY polynomial approximation to a function. Just for interest sake the expanded Chebyshev points for and arbritray interval [a,b] are given by:
[tex]2 x_i = a + b + (a-b) \frac { Cos ( \frac {2i+1} {2n +2} \pi)} {Cos( \frac {\pi} {2n +2})}[/tex]
Reference:
Elementary Numerical Analysis: An Algorithmic Approach by Conte and De Boor
Chebyshev polynomials for Lucas Sequences (LLT).
Thanks Hurkyl !
Yes you're right !
Hurkyl said:
So, in other words. [tex]T_n(x) = \frac{1}{2} S_n(2x)[/tex] ?
That works fine !
So it proves that [tex]C_n[/tex] has the same properties than [tex]T_n[/tex] has !
Tony
x in ]-inf ; + inf[ or x in ]-1 ; +1[ ??
Hi Integral,
Integral said:
It is not clear to me that if you move outside of the region [-1,1] that you are still dealing with a Chebyshev polynomial. The definition: [tex]T_k(Cos \Theta ) = Cos k \Theta[/tex] results in properties used to prove bounds on the resulting errors. If you do not have the cosine then all bets are off on the errors of the resulting function.
Yes, this is a good question ! My mathematical dictionary also defines Cebyshev polynomials by means of [tex]x=Cos \Theta[/tex] . So, can we still talk of Chebyshev polynomials when x is any real ?
My goal is to understand the relationships between the Chebyshev polynomials and the Lucas Sequences: [tex]V_n = P V_{n-1} - Q V_{n-2}[/tex] . I'm reading the book of Mr H. C. Williams : "Edouard Lucas and primality testing". Page 77, Mr Williams introduces the Chebyshev polynomials ([tex]C_n[/tex] and [tex]S_n[/tex], not the [tex]T_n[/tex] ! ) as a tool for building properties of the Lucas Sequences ([tex]U_n[/tex] and [tex]V_n[/tex]). He does not say what are the values of [tex]x[/tex] ...
(It appears that Chebyshev polynomials and Lucas Sequence share several properties. As an example: [tex]V_{kn} = V_n V_{(k-1)n} - Q^n V_{(k-2)n}[/tex] produces relationships very close (with k=2,3,...) to the ones of Chebyshev polynomials:[tex]V_{2n}=V_n^2-2Q^n[/tex] ...)
The interesting part is that [tex]C_2(x) = x^2-2[/tex] appears in the Lucas Lehmer test and that [tex]C_3(x) = x^3-3x[/tex] enables to find other valid values of [tex]S_0[/tex] than 4 . (Example, [tex]C_3(4)=52\equiv -10\pmod{M_5}[/tex] . And, with [tex]L_0=-10, L_3=0[/tex] proving [tex]M_5[/tex] is prime.).
Reminder: The Lucas Lehmer Test (LLT) for Mersenne numbers is:
[tex]L_0=4 , L_i = L_{i-1}^2 - 2=C_2(L_{i-1}) ; M_q=2^q-1[/tex] is prime iff [tex]L_{q-2} \equiv 0\pmod{M_q}[/tex] .
My questions are: 1) why [tex]C_3[/tex] produces numbers A (like 4) such that [tex]2+A[/tex] is a quadratic non residue used as [tex]L_0[/tex] ? 2) What are the properties of [tex]C_n[/tex] polynomials about Lucas Sequences when n is a prime ?
Tony
I think what I call here as [tex]C_n[/tex] is what I called as [tex]S_n[/tex] in the previous posts ... [tex]C_n[/tex] is the name used by Mr Williams.
[tex]C_0(x) = 2 ,<br /> C_1(x) = x ,<br /> C_i(x) = x C_{i-1}(x) - C_{i-2}(x)[/tex] .
  • · Replies 43 ·
13K
  • · Replies 100 ·
13K
