Why is Space Black? Can it be Explained?
  • Thread starter Thread starter kramer733
    Space
kramer733
Why isn't it any other color? Can it be explained?
Space news on Phys.org
The sky is blue because the air molecules scatter light so that you see not only light coming directly from the sun and stars but also all of the scattered light that eventually gets to your eye.
In space there is (almost) nothing to scatter light so if you are looking directly at a start you will see light from it- but no light beteen stars. No light means no color and, as Russ Watters said, no color means black.
More specifically, if you're seeing black, it means no visible light is scattering towards you from the region you're seeing black.
Olber's paradox, not enough galaxies and stars to fill in the gaps. Olber deduced our universe cannot be both spatially and temporally infinite.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
