Thread Closed
Help: Kinetic Energy and Friction -- A block pulled by another on a pulley
Share Thread Thread Tools
Jul18-10, 04:28 PM   #1
In the system the following diagram shows, the block M (mass of 15.65 kg) is initially moving to the left with a speed of 2.26 m/s. The mass of m is 8.26 kg and the coefficients of friction are μs = 0.411 and μk = 0.304. The string is massless and the pulley is massless and frictionless. How fast (m/s) will M be traveling when m has fallen through a height h=2.47 meters?
diagram: http://ce.byu.edu/courses/univ/69482..._blockmass.jpg
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jul18-10, 05:10 PM   #2
Mentor
Well, what do you think? What have you done so far?
Jul18-10, 06:41 PM   #3
The pulley makes it so that the second mass exerts a force purely in the x direction, not affecting the normal force. I used left (or down, for the second mass), as the positive direction.
The force exerted by mass m is equal to its mass times gravity, and delta-x equals 2.47 as provided in the problem. Therefore,
W = F * delta-x = (8.26)(9.8)(2.47) = 199.942
The normal force is equal to the weight of mass M, so the force of kinetic friction:
fk = m*g*μk = (15.65)(9.8)(0.304) = 46.6245
Using the following equation, then plugging in the values:
0.5*m*vf^2 = 0.5*m*vf^2 - fk*d + W
0.5*15.65*vf^2 = 0.5*15.65*2.26^2 - 46.6245*2.47 + 199.942
This give vf = 3.993 m/s, while the correct response is 3.49 m/s.
Jul18-10, 06:54 PM   #4
Mentor
Quote by aarno View Post
That's incorrect. Note that the masses are accelerating. You'll have to solve for the tension in the rope.
Thread Closed
Tags
conservation of ener, friction, kinetics
Thread Tools
Similar Threads for: Help: Kinetic Energy and Friction -- A block pulled by another on a pulley
Thread Forum Replies
Block pulled at an angle with friction Introductory Physics Homework 4
Block Pulled Up Slope/Coefficient Of Kinetic Friction. Introductory Physics Homework 6
Kinetic friction, pulley, inclined plane Introductory Physics Homework 0
Conservation of energy: Block pulled up frictionless plane Introductory Physics Homework 0
[SOLVED] Mass of a block via kinetic friction Introductory Physics Homework 3
