Why is our galaxy a disc and not a sphere?
In summary, the shape of our galaxy and other galaxies is largely due to the conservation of angular momentum as they form from collapsing gas and dust. The simplest shape gravity would form is a sphere, but there are also spherical galaxies that tend to be smaller due to a lack of angular momentum. In terms of our solar system, the objects move within a disc due to the same conservation of angular momentum, and material not in the plane of the disc is likely to get captured by it. This is why the orbits of our planets are aligned within our solar system.
p h i l
I hope this is the right place to ask this.
for a long time I wondered why our galaxy, or all galaxies for that matter, is more or less shaped like a disc. I assume this has something to do with the way gravity works. Yet I also assume that the simplest shape gravity would form is a sphere?
I know that there is a limit of mass needed to form a sphere (for stone,for example something like the earth, its a minimum diameter of 1000 km)
so is there a limit of mass needed to form a disc? is a disc just the next logical step in geometry as you increase the mass of a given object?
along with the problem posted above, the objects of our solar system also move more or less within a disc. why is that? why are the orbits of our planets aligned? why not set within a sphere?
I hope not too many questions at once ;) thanks a lot in advance!
Space news on Phys.org
p h i l said:
for a long time I wondered why our galaxy...is more or less shaped like a disc
Any big lump of gas and dust is likely to be rotating slightly.
As it collapses under gravity the angular momentum is conserved - this means a large thing spinning slowly becoming a smaller thing must spin more quickly.
As it spins more quickly it starts to flatten out into a disk - because stuff at the edges is pushed out.
Then it gets complicated - but basically anything that isn't in the main plane of the spin as it turns from a sphere into a disk is captured by the disk and added to it.
So whichever part of the sphere first lengthens out to become more like a disk will gradually attract all the other material and grow into a full disk.
There are spherical galaxies, they tend to be smaller ones and are just a group of stars and gas. Too widely distributed to pull themselves together into a smaller sphere but without enough angular momentum to spin into a disk.
That's slightly different - that's pretty much the maximum size somethign solid made out of eg. rocks can be before it's own gravity pulls it into a sphere. As the rocks are pulled together there is enough energy to melt them and you end up with a solid sphere of rock.
The density of a galaxy is so low (billions of stars but spread out into a space 100,000 lyr across) that the stars really don't feel each others gravity in any noticable amount
Again angular momentum, the rough sphere of gas they formed from shrank and speeded up - as the disk gets denser anything not in the plane of the disk (so anything orbiting the sun pole-pole) is likely to get hit or captured gravitationally by something in the disk and so all the other material gradually gets swept up. The same process captured all the little rocks around Saturn into it's rings for example
ah, I see. thanks for that quick and clear answer!
1. Why is our galaxy a disc?
Our galaxy, the Milky Way, is a disc-shaped structure because of the way it formed. When a galaxy forms, it starts as a large cloud of gas and dust. As the cloud collapses under its own gravity, it begins to spin faster and faster due to conservation of angular momentum. This spinning motion creates a flattened, disc-like shape.
2. What determines the shape of a galaxy?
The shape of a galaxy is primarily determined by its rotation and the amount of matter it contains. As mentioned before, the spinning motion of a galaxy results in a disc-shaped structure. Additionally, the distribution of matter within the galaxy, such as dark matter and stars, also plays a role in shaping the galaxy.
3. Are all galaxies disc-shaped?
No, not all galaxies are disc-shaped. There are different types of galaxies, including elliptical, irregular, and spiral galaxies. While spiral galaxies like the Milky Way are disc-shaped, elliptical galaxies are more round or oval in shape, and irregular galaxies have no defined shape.
4. How does the disc shape affect our view of the galaxy?
The disc shape of our galaxy allows us to see it as a thin, flat band of stars and other celestial objects. This gives us a unique perspective of the Milky Way, as we are located within the disc itself. This also means that our view of the galaxy is limited and we are unable to see the full extent of our galaxy's structure.
5. Can a galaxy's shape change over time?
Yes, a galaxy's shape can change over time. Galaxies can interact and collide with each other, causing their shapes to change. Additionally, the presence of dark matter and other external forces can also affect a galaxy's shape. However, the overall disc shape of a galaxy is thought to remain relatively stable over long periods of time.
