Leveraging with opposite forces
  • Context: Undergrad
  • Thread starter Thread starter Group014
    Forces
This discussion focuses on the mechanics of lifting a 70 lb. platform using a 3" tube and a 2 1/2" metal piece. The conversation explores the effectiveness of using two springs: one pulling down on the short end and another pushing up from the outside. It emphasizes the need for a strong inside spring, estimated to withstand approximately 500 lbs, while a weaker spring under the platform would suffice for the 70 lb. load. The discussion raises questions about the optimal configuration of springs and the application of the moment of force in this scenario.
  • Understanding of mechanical advantage and force distribution
  • Knowledge of spring mechanics and load calculations
  • Familiarity with the concept of moment of force (torque)
  • Basic principles of static equilibrium in physics
  • Research the principles of mechanical advantage in lever systems
  • Learn about spring constant calculations and their applications
  • Explore the concept of torque and its formulas in mechanical systems
  • Investigate different types of springs and their force characteristics
Mechanical engineers, physics students, and anyone involved in designing lifting mechanisms or analyzing force distribution in mechanical systems.
Group014
Suppose you have 3" tube acting as a post. A piece of metal is inserted into the pipe. The part inserted is 2 1/2" and the outside part 18". Your need to lift a 70 lb. platform resting on the external part of the piece of metal. If a spring is placed under the inside end of the piece it would pull down on the short end that is only 2 1/2" and needs to lift 70 lbs. You may add an additional spring to help pulling down on the short end or place a spring-out device (sping that pushes out or shock absorber pushig out) pushing up on the outside of the metal piece. As a result you would have a spring pulling down on the short end and a spring pushing up just a few inches from the pivot point. What would be better, using 2 springs on the inside end or a spring on the inside end pulling down and another on the immediate outside pushing up? Is there a formula to determine this?
It sounds like a fairly simple exercise in 'moment of force'. But your description leaves too many questions to be answered simply.
One thing that's obvious is that the 'inside' spring would need to be very strong to take the force on it. (about 500lb). A weaker spring placed directly under the platform would only need to take 70lb.
  • · Replies 128 ·
12K
  • · Replies 31 ·
